So I'm hitting heavy on fixing all the little things with this car. A set of eBay headlights was what i've started out with. Took a while and they still need some adjusting, but I am happy with the results! Soon i'll spray the stock corners amber and see how that looks on there. for now though, I'll sport the all black look! Check out these couple quick snapshots....
Still have a long ways to go. Hopefully to be done before the JBOM BBQ!!!
-Markus
2002 Yellow Cavalier LS Sport
FYI if you get up under your front bumper, there's enough room to drill screws through your lip and into the bottom of the bumper that cant be seen from the front. I had to to it on mine and it never came loose ever again.
SSLOBLT (StealthCavalier) wrote:FYI if you get up under your front bumper, there's enough room to drill screws through your lip and into the bottom of the bumper that cant be seen from the front. I had to to it on mine and it never came loose ever again.
yeah the tabs broke so i had to do a quick fix until i can figure out how to get under there and drill the holes. what screws do i use?
-Markus
I can help with the lip, I PMed you, so just let me know...
I dig the black tho! I say no Amber, Yellow and Amber just aren't right together...
I miss her^
in my mind, i always thought the amber would look killer on a yellow car. I'll try it and see, if i don't like it, meh, i can always put the black ones back in!
-Markus
I say stick with the black dude its pure sex right now!!!
You can also take the bumper off, then fasten the lip to it if that makes it easier.
Very clean. Keep the black, thats a deffinate.
M62, 42's, ZZP 3", ZZP S3 H/E
214whp 190wtq
EcoMark wrote:SSLOBLT (StealthCavalier) wrote:FYI if you get up under your front bumper, there's enough room to drill screws through your lip and into the bottom of the bumper that cant be seen from the front. I had to to it on mine and it never came loose ever again.
i used small bolts that i could put a nut on that way i knew it wouldnt shimmy loose. i considered a self tapping screw but after a while i imagine that the threads it creates in the bumper could wear out and then fall apart again.
looks great man. great changes in the short time youve had it
Member of J-body of Michigan.
mark cars coming along well, good to see progress on her. i say keep the black headlights they def look nice and cleannnn
thanks guys! Should be fixing a lot more here within the next couple days. I can't wait to switch over to Sportlines/d-specs either!
-Markus
EcoMark wrote:thanks guys! Should be fixing a lot more here within the next couple days. I can't wait to switch over to Sportlines/d-specs either!
you buyin em off jayvan?
looks good, I'm with everyone else...black on yellow is better then amber on yellow...contrast just isn't right
Qwik2k2z24 wrote:That would be awesome news to me! Sent you a PM Mark. I will include full install with purchase!!!111!!!one!!!
you've got a deal!
-Markus
Special thanks to Rob Weis (RobsCavZ24). Helped me with the car yesterday. Sunroof is at least in it's proper place, side molding it removed and the toyo tails are in! Check it out. i took a few quick snapshots!
There is still a large amount of glue left over from the side molding. A friend of mine is helping me detail it and clean it up but unfortunately it won't be before the JBOM BBQ so i'll have to show up with the glue still on the car. Other than that, the only other thing to fix is the front lip!
See you guys at the BBQ!
-Markus
I would leave the lights that way they are, IMO Amber would not go good with the brightness of your car.
James (ROLN19S) (JuicyJ) wrote:I would leave the lights that way they are, IMO Amber would not go good with the brightness of your car.
I have since changed my mind about the corners. But i still have the paint just in case
-Markus
looks really good! door dings are comming...
Looks good!!
WOOT for toyos!!!!!!!! i relle need to get some for my 4door
"still want to smash that like the fist of an angry god"
Can I have your camera?!?!?!
Its coming along nicely
i liked every thing till the head lights
nice pics tho
