Running a stock short block tell next year.
Also finally got around to wiring and getting the SHO t/b on.
every thing seems to be working well.
few secret exterior mods for this year also.
Mod list for this year.
Stock short block 95-99,
ported 00 up head,
HO intake manifold ported and matched to head,
stainless valves,
2.3l valve springs,
2.3l HO 410 lift cams,
89 2.3l cam towers,
Ford Taurus SHO T/B 65mm,
Ford brown top injectors,
bills & Stains header,
2.5" exhaust
Unorthadox aluminum flywheel,
spec stage 3+ clutch,
spec pressure plate,
nvg trans swap,
custom shift cable bracket b7m short throw shifter,
solid mounts,
2.3l power steering not fabbed up yet,
That's all i can think of at the moment.
On to pics.
some pics kinda suck I know this.
engine bay less than a month ago.
shift cable bracket
camaro rolling up on me yesterday.( I made the hood)
camaro owner is a friend.
Also time will be posted soon hitting the track Saturday
Most likely more pic later tomorrow
Thanks,
Paul
More info on making the tb work!!! And cant wait to see times, even with the stock bottom end
Yeah where is the rest of the technic bumper?
shhhhhhhhhhhh thats a SECRET guys!!!! hahahaha
paul-u werent sh!ttn when you said that you need to clean the bay man
SO glad this thing is finally back on the road... hopefully we can have some fun with our cars before you leave.
ps.. where can i buy a bills and stains header?
Riddle me this... riddle me that...
John Higgins wrote:Yeah where is the rest of the technic bumper?
Please tell me you are going to produce these!!
iam making a female mold as of right now. so we Will have a mold to pull finished parts from.
But right at the moment Iam making a copy for my self and Brad will be getting the original.
But like i said we will still have a female mold of it.
Meaning all we need to do to make one is lay glass on the back side of the mold and pop it out flawless with lil to no sanding.
T/B you have to plug a bunch of holes on the inside of the T/B drill one new hole on the back side of the butterfly towards the intake manifold that hole is used to pull vacuum on the brake booster.
other than that NO IAC idle air controll you set the idle with a screw. make a throttle cable slot hole so it lines up to manifold holes.
Ill go into more detail later.
LOL thats right, fords damn old school IAC....
hmm
Chris
'02 Z-24 Supercharged
Nice, I love the boonies..Reminds me of home.....
Paul Tjepkes (N/A MADNESS) wrote:iam making a female mold as of right now. so we Will have a mold to pull finished parts from.
wow you suck, thanks for keeping it a secret you @!#$!!!!
Brad what are you talking about...........?
your new whiteboy technic lip.
does it have stains on it?
z yaaaa (the riddler) wrote:does it have stains on it?
ihavenolife000's did after i started playin with it
z yaaaa (the riddler) wrote:Paul Tjepkes (N/A MADNESS) wrote:iam making a female mold as of right now. so we Will have a mold to pull finished parts from.
molds ftw!!!!
http://www.myspace.com/fpsunfire
5 seconds to find another street...
14.301 @ 95.65
2.21 60 ft.
lol no track.
Races got canceled I am also still having problems with my clutch being delay after being pressed down it is delayed slightly on the back travel making hard to shift fast.
installed new master cyl today didn't help one bit but i needed a new one anyways my was rigged to work but was broke off the firewall.
Any ideas on the clutch I also used a slave cyl I got with a nvg tranny so it was used.
Iam starting to think that might be the problem.
i got the header
I have one in the garage as well........ and a DC Sports header too
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
Paul Tjepkes (N/A MADNESS) wrote:lol no track.
what clutch/flywheel setup are you running, ur running an nvg tranny but are u still running the isuzu clutch/flywheel combo? when i got my spec clutch i ordered one for the car the nvg came in and i also picked up a matching fidenza flywheel (we all know ur probs with one but this is for the sake of matching ur clutch/flywheel) there is nothing wrong with running the isuzu setup, you just cant use the supplied slave. i went through tons of probs reusing the nvg slave the trans came with so thats why i opted to buy the nvg clutch/flywheel setup (as well the flywheel isnt stepped) but in the end they sent me the wrong slave and i had to do a little work...
nvg vs. what spec sent me
the little modification
final result
now my whole setup works like a dream
good luck man, i cant wait till you get her on the track
looking good man... looking good.
Desert Tuners
NICE!
Good job on everything.
i got the header
asshatt!
Chris
