wow HUGE difference!
look great!
My car was made with wrenches, Not chopsticks.
Amazing!! Just means that I gotta get mine out soon and clean for the spring
M62, 42's, ZZP 3", ZZP S3 H/E
214whp 190wtq
Those look killer! They'll look awsome on the car
Member of J-body of Michigan.
I'm gunna be doing that to the wheels i picked up from DTP.
Do the inside ot the wheel too
^^ i just did the insides of those to wheels and now i need to repolish them
i also cleaned up the other 2 front and rear i should have pics of all 4 by tues or wed if i work on them after work this week
what did you use to clean and everythign to get that shinny?
03 cavalier
us amps 100hc running at .5 ohms
digital designs 3512
yellow top g34
kenwood ddx-8019
To polish the wheels like that, usually you take a mild sand paper and work up to a very fine grit sand paper. Once the oxidation is removed and all the scratches have been removed from the very fine grit sand paper then you go back with some alluminum polish and buff them like crazy.
At least that's how I do it.
sikcavy wrote:what did you use to clean and everythign to get that shinny?
Try reading. He explained everything at the top
Steve W wrote:To polish the wheels like that, usually you take a mild sand paper and work up to a very fine grit sand paper. Once the oxidation is removed and all the scratches have been removed from the very fine grit sand paper then you go back with some alluminum polish and buff them like crazy.
well your totally wrong.
why would you sand CHROME rims these are NOT polished aluminum they are dipped chrome.
again
washed with dish soap to remove the grease and stuff.
used SOS pads 1 per rim ( they are meant for CHROME do not use on polished aluminum)
then i polished by hand with Never Dull Chrome Polish.
ok looks like i will be getting sos pads.. i have a set of mr7's and the break dust killed my rims... i tried westleys bleach, and i tried waxing and i couldnt get the stain and stuff off.. hope this works.
03 cavalier
yellow top g34
kenwood ddx-8019
i hope you clear them. i heard they make clear that sticks to polished metal. or else those will be brushed aluminum in no time
Working on obtainting an M-Class license... ?? Hint: 2 wheels.
^^ do you people not read they are NOT POLISHED METAL
they are CHROME........................
Those are some good looking polished metal, not chrome, rims you got there Greg.
I kid!
umm... they're chrome. you didnt 'polish' anything. you cleaned them.
the work you do gets done every time i drive my car. sometimes twice. its not hard.
Needing 2.3 oil pump stuff? PM me...
Shiny polished metal wheels ftmfw!
I kid too..
Good job on the cleanup.
FOR SALE
VIPERREDZED wrote:DONE
10+ hours into these things now
10 hours?... you kidding me?..lmao.
why wast so much time when the same thing can be accomplished so easily in just a few minutes per rim if you used some cleaner and something like this
And even not that specific type of item, one of any other countless things like it for cleaning rims..
but whatever, i wouldnt waste 10 hours cleaning rims..
how do you get 10 hours in cleaning 4 rims? yes i said cleaning... because you didnt 'polish' them.
Well done Greg...they look sweet..!
z yaaaa wrote:umm... they're chrome. you didnt 'polish' anything. you cleaned them.
z yaaaa wrote:how do you get 10 hours in cleaning 4 rims? yes i said cleaning... because you didnt 'polish' them.
The first post wasnt enough?
Got Chevy? wrote:VIPERREDZED wrote:DONE
That's what I used of course I had aluminum rims.
Do you never end............... read the first post and YES i DID polish them with CHROME POLISH..............
the rims had never been cleaned probably in there life i had to get all the brake dust and grease and crap off before i could even think about cleaning them up
