Your car makes me happy in my pants.
"spill" proof keyboard is put to use yet again.......
JGM T-SHIRTS!!!!
Nice location of the nozzle.
^^ its the new plate zzp just put out
thanks guys!!
Edited 1 time(s). Last edited Thursday, September 17, 2009 7:57 PM
Fan? Yup sure am one! so clean and so nice looking. and VERY well hidden.
Thats super hot!
NICE! More info on this plate??
Ok, now I see the plate. No interference with the hood hitting the tps connector? I know the one s/c I've installed that was an issue and there wasn't a 1/4" spacer in there. More curiosity than anything at this point.
Misleading title.
I was expecting nude rave pics.
I love this car...Does that spacer not give you clearance issues?
nice , but i think the best cooling effect would be with the spray before the s/c atleast for cooling
though i think the spray in that plate should enter from the top to the bottom , so it flows with the air instead of against it
as i have said many times, your car is the defination of sex!
nice, and i also see an eco on the ground and a fire? in the background with out a front clip :O
13.22 @ 105.2
Where the nozzle is located is the 2nd best place to get the cooling benefits of meth, the first being direct injection. Reason being it's after the air has been compressed, we all know that when air is compressed the temperature of it increases. By spraying pre blower you would cool the blower itself, but the drop in intake charge temp isn't as significant as what should be seen with the nozzle located after the blower. Another benefit to having behind the blower like this is the water/meth droplets will not be hitting the blades of the supercharger, which could cause damage at the velocity it's traveling at.
skunk hit it right on the head, not an exellent idea to spray pre-blower, although some don't have a choice like the 2.4 guys (maybe able to drill and tap the s/c but it would be a challenge) Also a good chance of wearing out the charger. As for spraying upwards rather than down, i had thought about that before i put it on, but in my hast i forgot to play with it putting it on lol, but it would have been a PITA to turn that plate upside down than get the gasket between it and the charger, the holes came pre-drilled so its not like a had much choice. In the end tho i'm sure 14psi of boost is no match for my 150psi meth pump lol
as for hood clearance i was @!#$tin bricks the hole time, didn't have a clue if it would work with the J, but gave it a try anyways, 1st clearance issue i noticed was the fuel rail, but it ended up just barely clearing. And as for clearing the hood, i checked it when i 1st put the plate on and it cleared, i thought i may have problems with the nippe for where the cobalt tmap goes, but it seemed ok, Now on the other hand i haven't popped the hood and look for marks now that i've went and beat the @!#$ outta it lol. Will later today.
The plate is 1/2 thick, 2 ports in it, from zzp..
http://www.zzperformance.com/cobalt_ion/products1.php?id=970&catid=174 only @!#$ty part is i had to take off the brand new stage 2 belt i just bough a month or so back lol.
Yes Jean, waiting for someone to notice that, lol you do see an eco and a J shell....that cat will be let outta the bag shortly, and i can assure everyone they will need computer covers when we let her out
no need for a sunroof..................
Edited 1 time(s). Last edited Friday, September 18, 2009 4:48 AM
I like where you put the pump. I'll try to remember whenever I buy mine
very nice. yes my hood clearance is very close on my tb. will have to keep this in mind. have a gal of meth at home waitin for usage.
my carDomain updated 8/10/09 Forged and no boost
nice job on your car though, looks clean, thats where i mounted mine, just sideways, you just use your winsheild washer for a tank?
seeing your car makes me wish i didn't do a cav front, its SOO nice man, did a great job on this fire.
13.22 @ 105.2
forgot to ask, did you change your injectors too?, i see you took the fuel rail off
13.22 @ 105.2
this is by far the best looking sunfire i have ever seen!!
