My Progress build 2200 -> Z24 - Photos & Media Forum
Sunday, January 31, 2010 7:06 PM
ok so, i just got my new block so im starting my progress build from my LN2 into my LD9. its going to be a long build seeing as i have the block, head and oil pan. its going to be a complete rebuild so bare with me.
here is my LD9
wish me luck with this build, im going to need it. my goal for this car is 300hp boosted. so if you are selling any parts for this LD9 including a 5speed transmission wiring harness, ecu all the goodies
Re: My Progress build 2200 -> Z24
Sunday, January 31, 2010 7:12 PM
i would have gone with the eco swap. only because part are way easier to find in good shape.
Sunday, January 31, 2010 7:16 PM
A boosted LD9 will work just fine. Keep me posted.
GMR has got nothing on this
Sunday, January 31, 2010 8:52 PM
nice, good luck josh, and for god sakes please don't try and paint it.
Sunday, January 31, 2010 9:20 PM
good luck! should be exciting
Monday, February 01, 2010 2:32 PM
one day id like to do a engine swap... just dont have the funds right now...
good luck with the swap... should turn out awesome!
Monday, February 01, 2010 4:09 PM
Im confused. So youre putting an LD9 into your car which is a 2200 correct?
Monday, February 01, 2010 4:19 PM
correct
Monday, February 01, 2010 4:46 PM
sub'd for updates!
Sunday, February 14, 2010 8:55 AM
little bit of an update on this i thought that the 3ed cylinder was going to be completely f'ed up turns out its not that bad heres pictures of the tear down
some carbon build up but not nearly as bad as i thought it was going to be 100k miles on the motor
chick that had it before me didn't do oil changes when need be and used non synthetic oils >.< look at that build up
oh noes look at the prob!
Sunday, February 14, 2010 10:02 AM
Who called 3rd cylinder? What bitch?!
Sunday, February 14, 2010 10:18 AM
lol i think everyone
easy fix, as soon as i get my hands on the donor car its on like donkey kong
Sunday, February 14, 2010 10:19 AM
fail1
Edited 1 time(s). Last edited Sunday, February 14, 2010 11:04 AM
Sunday, February 14, 2010 10:28 AM
fail2
Sunday, February 14, 2010 10:29 AM
Good luck man i cant wait to see this build complete keep us updated
Sunday, February 14, 2010 10:30 AM
fail3
Sunday, February 14, 2010 10:55 AM
nice quadruple post.
Sunday, February 14, 2010 10:56 AM
we got it the first time holy 4 posts i think you hit send tomany times
JBO since July 30, 2001
Sunday, February 14, 2010 11:03 AM
wtf? lol!
Sunday, February 14, 2010 11:10 AM
lookin good josh. psyched to see ya get this done.
Sunday, February 14, 2010 11:15 AM
im not fluent on the ld9s but in this pic when u removed the oil pan is that the crank bearings under neith the part with the mess screen??
Re: My Progress build 2200 -&amp;gt; Z24
Sunday, February 21, 2010 9:04 PM
you got a long road ahead of you.... now is the time to get your motor internally sound
Hit up Karo and get
Forged pistons (you tell him the comp ratio you want)
Eagle Rods
ARP head and main studs
Spec Stage whatever Clutch and flywheel
1mm oversized stainless valves
then find you a 2.3 oil pump and accessories
get the block modified to accept the 2.3 oil pump
while its there, get them to knife edge your crank 3 lbs and balance it and mic it for the correct size bearings (go clevite 77)
then get you some HO Springs and Retainers, and lifters, HO Cams and housings. Get the intake cam modified to work for the 2.4 (needs the cps pad and ps pump insert)
now you're ready for turbo!!
Edited 1 time(s). Last edited Sunday, February 21, 2010 9:06 PM
Re: My Progress build 2200 -&amp;amp;gt; Z24
Monday, February 22, 2010 10:29 AM
Cursed Cav Online
I agree with the above, except for knife edging the crank and the spec clutch. If you've got money to blow, go ahead and knife edge it, but there is little to gain in the area of the crank. And don't waste your money on SPEC. Complete garbage. Throw in a stock Luk clutch and you will be good to go.
1999 Grand AM SE (Beater Car)
1997 GMC Sierra
2007 Honda CBR 600RR
2005 Honda TRX450R
Re: My Progress build 2200 -&amp;amp;amp;gt; Z24
Monday, February 22, 2010 11:26 AM
good luck man. keep us posted
Re: My Progress build 2200 -&amp;amp;amp;amp;gt; Z24
Monday, February 22, 2010 3:58 PM
I would like to second Spec being crap.
Also, kinda bothered by people like you who say "used non-synthetic" as a big issue. It's a bone stock econobox that was built and designed with the use of conventional oil. I don't see an issue. The intervals are the problem, not conventional oil.
In my family we teach that boys have a God-stick and girls have a Shame Cave. -John Stewart
