looking for some pics of how you guys have your sides mounted and what it lookes like inside the door jamb area? i mocked up my sides and i dont really know what its supposed to look like in there so i'm not sure if they're lining up good or not
thanks alot
www.driftnamiperformance.com
I dont have any pics of the door jam area, but all you do is screw them in on that lip of the jam. I did 3. One screw right beside fender in the door jam, one in the middle, and one at the end where the door closes.
ok, i'm just trying to avoid having to screw them in in the door sill, i saw theres double sided tape on them under the lip, i'm thiunking if i replace that and use the screws on the ends it should be alright no? or would you reccommend actually using screws
on my first car i had screws in each of the fender wells and double sided tape all the way across to keep them flush to the car, but after a while they started to separate from the body and fold under the car. So when I installed them on my 00z24 they where riveted into the door sills so they sit flush. It sucks to have to rivet or screw them in, but they really don't sit right if you don't. I hate seeing pictures of them on peoples cars and seeing them folding under the car.
oh ok, well i'm gonna try the double sided tape and screws on the fender wells then probably use some seam sealer too and see how that goes, if not i guess i'll have to break down and use screws, i'd like to have a smooth surface inside the door but you gotta do what you gotta do though
if anyone has pics of inside the doors or can get some i'd appreciate it either way
Don't use screws! There are only 2 screws you should use and that would be one in the front and one in the back. The tape you want to use is called 3M VHB tape. It's the strongest there is. Remember to use a surface prep to clean any areas the tape will contact. Prep-all or Acetone work good. Do not scrub with these solvents, just lightly wipe. If you use a heat gun on the tape to warm it up before you stick the skirts on it will promote even better adhesion. GL! Post pics b4 lock tho!
will do, it's a beautiful day today so i may just try and get them installed today if i can find some tape somewhere
Steve-O wrote:will do, it's a beautiful day today so i may just try and get them installed today if i can find some tape somewhere
If you do, use nothing more than like a 3M scotch-brite pad #7445 or if they don't have that a #7448 would work too.
Yea don't use screws, see what happens when you kick the skirt a couple hard times, that double sided tape will start to give. That was how I first attached my skirts, that quickly changed.
we'll see how it goes, another thing i was wondering is what abou the tabs on the underside? just screw them up through the frame rail or what?
WHITECAVY(the bash falln one) wrote:Yea don't use screws, see what happens when you kick the skirt a couple hard times, that double sided tape will start to give. That was how I first attached my skirts, that quickly changed.
Screws are not necessary. My 3M VHB has held since July 2006. You must not have prepped the area well, or either that you used cheap tape. Side note....Don't kick your car either....
yea what tabs ? IF sides dont have tabs like stock skirts
SEC-Z wrote:WHITECAVY(the bash falln one) wrote:Yea don't use screws, see what happens when you kick the skirt a couple hard times, that double sided tape will start to give. That was how I first attached my skirts, that quickly changed.
You haven't seen my car, I cheap out on nothing on it. Even tape. I stand by my claim. We all do it different.
2012 numbers - 4SPD
AUTOMATIC!!
WHITECAVY(the bash falln one) wrote:SEC-Z wrote:WHITECAVY(the bash falln one) wrote:Yea don't use screws, see what happens when you kick the skirt a couple hard times, that double sided tape will start to give. That was how I first attached my skirts, that quickly changed.
I've probably seen every single one of your posts here in photos and media. I am very familiar with you car, and it is extremely well built...i agree with you on that. But as for using screws and putting unnecessary holes in the car...I guess on that part I will just agree to disagree.
Quiklilcav wrote:Steve-O wrote:we'll see how it goes, another thing i was wondering is what abou the tabs on the underside? just screw them up through the frame rail or what?
What tabs?
These..
you bought them new right?
maybe a change in design?? maybe thats to adress the issue that homiej was talking about? it looks like those tabs would work well to stop them from "folding" under the car
Steve-O wrote:maybe a change in design?? maybe thats to adress the issue that homiej was talking about? it looks like those tabs would work well to stop them from "folding" under the car
yeah that would definately help the folding under issue, with those i don't think you would need to worry about using anything other then something like the 3m double sided tape to get them flush with the body of the car.
wow thats  different.. alot better though i would say. gives it more support rather then just hanging there
hm, well WIN i guess lol
Those are what mine look like, don't reallt think that is a new design since mine are from 2004
