Hello all, a couple people wanted to hear my idle with the exhaust hooked up with the oldschool cams in. Its a little choppy and lots of vibrations but I kinda like it. Sounds a lot deeper in real life.
nice
8 psi with m62 and IAT under 100
I know its not an idle like a 226 or 224 cam but it seriously does shake the dash.
Not bad, was hoping for more lope. Ho cams right?
These are 87 2.3 cams. They have the same duration as the HOs but only .340/.350 lift. I was going for the midrange torque in this engine since it will eventually go into the DD vert. I actually have had all these parts laying around so its kind of a frankenmotor with stock bottom end. Now that the Z is running again after taking off the 086 head I can slowly start on its real engine.
Zs Z wrote:I know its not an idle like a 226 or 224 cam but it seriously does shake the dash.
add a few more degrees........
I like it. To bad I only have a tiny .370 exhaust cam in my 02 right now.
Edited 1 time(s). Last edited Wednesday, June 23, 2010 10:16 PM
sounds like if you would mate a pressure washer and a popcorn machine.
gmanz24 (The Bash Whore) wrote:sounds like if you would mate a pressure washer and a popcorn machine.
Haha I agree but it has a much better tone in person. I recorded this on my cellphone so the tone is waaaaay off.
