I've been quiet.
Here's why:
My 2004 DD coupe
a few days later....
I had the swirl... running with an LSJ/L61 hybrid engine.
The skwirl has a working drivetrain, but is not everyday friendly.
Blue was an everyday friendly car without a working drivetrain.
some pillaging needed to happen.
special tool I made to get the pesky L61 out of Blue.
with the L61 out, and the 2005 L61 head off the LS61 sold to a friend, I decided to reunite the LSJ head to the LSJ block, and run a straight up LSJ swap in Blue.
setup:
2005 LSJ ecotec engine 2.0L
-arp headstuds
-cometic headgasket
-balance shaft delete
2005 F23 getrag transmission
-LSJ clutch
-LSJ trans spacer
first I needed to figure a better way to mount the crank shaft position sensor
this little beauty puts the sensor in a nice safe location, and also replaces the water pump access cover. Nice, secure, and stock.
then I needed to modify the intake manifold/ head in order for them to marry together without troubles
drilled and tapped the PCV port on the LSJ head for NPT threads (I forget if its 1/4 or 3/8)
stock L61 intake manifold bolts are too small for the LSJ head
size comparison
LSJ intake manifold bolts won't fit through the LE5 intake manifold
so I ordered some special bolts and knocked out the brass sleeves in the intake manifold in order to get them to marry.
I also had to clearance the intake manifold around the PCV port
I then had to weld shut the stock PCV gasket on the LE5 manifold
mock up
LSJ in the car
beginning to fabricate the cam sensor block off (keep this in mind for later..)
LSJ ignition cover
time to abrasive-blast
after a few minutes, no more ugly spray paint
now that its clean, time for some machining
all done
here's why
the LSJ ignition cover will hold the L61 ignition down in place in the LSJ valve cover.
fixing aeromotive's fuel pressure regulator (it's 1/16NPT... I needed 1/8NPT)
machining some more parts
what the hell is this for....
intercooler and oil cooler mounted up to plate that bolts to the bottom of the radiator core support
mounted up
after a tiny bit of bumper trimming, fits like a god damn glove
ended up having to use an aftermarket crank pulley so the trigger ring would sit flush. here's a nice view of the VR sensor bracket I made
top down view showing clearance
from the bottom up
I turned gay and made 1" thick rear wheel spacers. (with the saturn disc brackets, I have a 3" wider track in the rear)
before space
after space
another shot.. yea my tires are narrow.. time to upgrade.
custom fabricated battery tray
mounted up
time to do the pesky exhaust....
3" front to rear.
all v-band
all stainles steel
magnaflow spun cat
magnaflow resonator
magnaflow muffler
muffler bracketry (muffler is fixed in place, flex joint is in the downpipe)
mounted
I used a prebent cat-back system from Mandrel Exhaust Systems and was severely disappointed with the fit. After cutting the pipe and reshaping it a bit I got it to fit beautifully. I have over 1/2" of clearance on the torsion beam with 3" exhaust piping. Way better than the skwirl ever had.
ground clearance isn't bad either
exhaust finished early in the morning fog
F it... I'm stealing the manual brake setup from the skwirl too....
but I'm going to remake the adapter plate so that it actually FITS this time
looks a lot better with that little bevel on the edge
looks a lot better with stainless steel hardware too
painted and mounted
what to do what to do...... you know what? I don't like my cam sensor block off plate....
I think I'll put the PS pump on the exhaust cam instead of the intake cam.....
gonna need this to extend the hex drive a little bit (this is before I trimmed it down)
time to clean up that aluminum piece...
again, stainless hardware. countersunk the mounting holes so they didn't interfere with the pump.
F-ing beautiful
sooooo much room for induction now when I throw the turbo on it
manual brakes are a necessity for moving the PS pump
almost done.....
I'm a few days away from completing the car and starting it up.
comments welcome.
