how the f*ck do i burn out i have a 2.2 4cylinder automatic engine in a 97 cavy and i cant do it how?????/
that's what i got...  and i can tell you that without a turbo, it ain't happenin.
ebake    and     have your foot by the brake    so it decides to let go .     by the way the tire smoke will come thru the vent and smell for about an hour.
put your car down in the lowest gear(1), pull the ebrake up as much as it will go and stomp on the gas. If your that under horsepowered than try to go on a smoother pavement and if all possible do it when its raining
first, eat white castles
second, drink a few beers
third, @!#$ your pants and wipe it in front of your tires
fourth, rev your rice burner up and throw it in drive.
Last your tires should start to spin then hit bare pavement and you have yourself a burn out.
tada
  http://www.j-body.org/classifieds/miscellaneous/60612/
lol i was just wondering i can do it when its wet and in my works parking lot
This is like me asking how to do a burn out in my 1.8L Geo Prizm.
You need wet pavement and e-brake, back tires should be on dry pavement.
Hold brake and gas till car wants to move then let off brake peddle and floor that beast.
Or just floor the beast from the start with the e-brake on.
cannon fodder wrote:that's what i got...  and i can tell you that without a turbo, it ain't happenin.
put donuts on the front of yer car  in the rain.. and have 5 of yer buddies lift up on the front of yer car... other then that..... i agree with tony..... its not happening lol
 Shush Weasel..i want my shirley temple
stupidest post EVAR
Haha.. This is pathetic. Your car requires torque and power to spin the tires that fast. Even with the ebrake pulled he will probably just stretch the Ebrake out.
seriously its jsut a question idk im new i put one in the newb forum but noone ansewrd
yall dont have to be dicks seriosly gohs how did you gusy learn all this
asking questions
Tire shine sprayed all over the tread . That will give you a nice BIG smokey burnout .
 <a href="http://users.adelphia.net/~rdbryant1/index.html.html"><img src="http://registry.gmenthusiast.com/images/mrgoodwrench/personal_pic.jpg" border=4></a>
if you have loose gravel and stuff on the pavement, i've gotten my tires to spin with that mixture, but it aint all that cool
"Official Jewish J-Body"
drive onto a frozen lake and hit the gas
If you're not too terribly fond of your transmission there is always the (sinister music here) TRANNY DUMP.  These are instructions on how to dump the tranny- be warned, it's called a tranny DUMP for a reason.
1.  place transmission in neutral
2. rev engine to about 4k
3 slap it into gear and ......
WOOOHOOO
It posted before I was done writing there.
I was going to finish the story of the tranny dump with a moral.
You will get about a second of spin and then you will feel a sickening THUNK as your transmission goes the way of the dodo.
put bleach on your front tires and on the ground.
Find a hill. Let it roll down once your going a lil fast punch the gas and there you go. Or you can just
put the car in netural.
Rev it while holding the brake (this will make the brake harder)
Then let it idle and put it back in drive
Rev it a little bit (as far as it doesn't move)
Pull the e-brake
While holding it in rev while holding the brake let go of the brake and floor it and let go of e-brake if the car starts to move a lot
just pour motor oil all over your tires, and let her rip, it did it to my 2200 auto, but its a mess i would not do it again nor recommend trying to do it.
i've learned throw many years that auto cavy trans break very easily
hehehehehe
yay runnin mid 18s by summer
two words neutral drop
this works maybe a little dangersous but it makes my g/f's 3speed 97 cav peel the tires nice
just put that car in neutral rev it up to like 4-5grand, let go of the gas and before the car revs down pop it in drive and go on the gas midway or all the way
2000 Dark metallica green cavalier. (2.2 2200) pace setter 4-1 header, magna flow cat, dual quad tip dtm muffler, 1800 watt stereo with satalite radio, momo 16in rims, from rk sport strut bar, rear vibrant strut bar, indeglow gauge cluster along with matching hvac panel, clear corner lenses, altezz tails, vibrant wai, carbon fiber oem style hood, rsm lightened crank pulley, MSD Ignition coil packs, RSM Vortech Supercharger 8psi
"Disarters are just another star falling in my yard."
why do you wanna do a burnout......its dumb and bvad for yer tires
Not unintentionally accelerating since 2009!!!!
