Car stalls whlie driving and has trouble starting. - Newbies Forum
Friday, September 09, 2005 10:26 AM
Hey guys im new here and basically joined to see if anyone had the same problem i am having and if they found a soloution to it. Well i have a 94' Z24 with a 3.1. with about 88,000 miles on it. The motor makes a tapping noise and thinking its a lifter. I dont really know if that is contributing to my bigger problem which is that the car will stall whlie i am driving. It is also a pain to start once in a while, sometimes taking 20 minutes! The battery and the alternator are both working good so i have been able to eliminate them from the problem.... if anyone out there has a possible soloution to this nagging and somewhat dangerous problem please e-mail me... the address is thegreat1650@aol.com if i dont have it posted on here. Thanks for the help!
Re: Car stalls whlie driving and has trouble starting.
Friday, September 09, 2005 10:55 AM
starter? ignition switch?
Friday, September 09, 2005 11:04 AM
starter
-Borsty
Friday, September 09, 2005 12:36 PM
could be that your computer is going bad. mine use to do that then the computer completely died
Saturday, September 10, 2005 12:31 AM
What kind of condition is the fuel filter in? Has the car had a tune up plugs wires etc?
Any Engine light on? Has the fuel pump been tested for the correct Psi?
Sunday, September 11, 2005 6:56 PM
i would say egr i had a 94 grand am gt with an egr problem did all of those things
Sunday, September 11, 2005 7:55 PM
Ron Love Online
It always helps to have the specs about ur car in ur registry!!!!!Do you have a automatic or manual trans?While the symptoms u described are not really out of the ordinary,U really need to be as specific about the issue.U said it dies while driving it,so is that while u are moving at 35mph or coming to a stop.Please clarify this so we can better help u to narrow down the issue.I cannnot really post so various things that may cause just that there are so many.Please tell us if u have done a tune up on it if so,what did u replace,and we can fix this issue.OK and the starter and ignition switch swtich would clearly NOT be the problem while the car is running.
