I Had A 97 Cavalier and had a white face gauges put on but it began to loosen around the 40 to 50 mph range. I Have a 96 Z24 and I don't want the same problem. I don't know if it was because it was the summer in Virginia or what but if anyone knows if winter would be the best time or if there is a glue to use along with the adhesive backing would really help. Thanks.
maybe you didnt push it down all the way or something. if it happens again then just use some tape. i guess just use doublesided tape next time, or if its easy to hide, then use duct or electrical tape
Hey Newbies; Dont Search Ebay, i got what you need right here
Here is a suggestion...
If you want gauges, don't use the cheap APC stuff. If you want something good, spend the good cash for a custom made (to your personal liking) Gauge Cluster. It's not just the face...it's a full cluster replacement. You can do anything...put any type of background, put any type of wording, you can even put it to 200 MPH if you wanted it to say that.
Here is what mine looks like:
You can contact them:
Black Cat Customs (www.blackcatcustom.com).
Thanks BLUE]ShiftyCav and Thanks
NJHK (King Of Newbies) I will look into both suggestion
lowgeeman wrote:Thanks BLUE]ShiftyCav and Thanks NJHK (King Of Newbies) I will look into both suggestion
No Problem.
Also, if you want to add that picture as your signature, go into your control panel and you'll see forum options...you put the image code with the source like you did just now.
Before you do that though, change the size. The
has a limit of 500 x 200.
cool thanks again hope this works
You have to put the image code
[ img ] location of the picture [ / img ]
(Put it all together)
thank you kind sir a little slow to-nite
It's no problem, that's why I'm the King
