Hi,
Was wondering what motors and 5 speed transmissions will fit in 1998 Cavalier 2.2, 5 speed?
thank you,
Nathan
With a little work, pretty much anything will fit. Probably not what you wanted to know...
What are you trying to do?
Caddy Northstar, 3800 S/C, 3800 N/A, 3400, 2.2L ecotec, 2.4L quad 4, 2.2L OHV all fit in a cavalier engine bay with a 5-speed, but some require more work/fabrication than others.
219whp - I <3 whine
Thanks for the input, but i was meant what will directly fit into my car. i was really wondering if a 2000-2202 motor will directly fit into my car and im pretty sure only the 95-99 trannys will work because the mounts are different, but im not sure.
i have a? about a motor i bought. The tran was an auto,mine is manaul.The prob is the fly wheel bolts won't line up.I was told the new motor was a canadian motor.Is this true,if so.What do I do?
what ENGINE did you buy, year, size, transmission, and what ENGINE are you starting with, year, size, and transmission?
the only engine that will fit in it directly is what is in it now
anything else will require mods
-96 cavalier 2.2 auto 143k miles
