Dirt track race car.
Just wondering about a little more easy power?
Are the cam swaps I read about on here to get a quad 4 up to what my motor allready is?
I can change the air cleaner to anything I want, what would you suggest?
Would I benefit from diff injectors?
Stock exh manifold is required, no muffler, cat etc. just straight pipe is ok. is that the way to go? or does it need some back pressure?
The car I have runs awesome it seems to have a lot of power up top, not a lot of midrange.
www.jnjfab.com
Is my website i build and sell race ready 4 cyl dirt track cars.
I usually race rwd but run some of the 1000 on up to win 4 cyl races in the area.
Race ready fwd 4 cyl dirt track race cars for sale.
www.jnjfab.com
email me at istock66jj@cs.com
send pics to iowawhitetails@hotmail.com
just seen your pics on website. still have 97 cavalier?
HO quad..... a W41 chip and a under drive pulley would be a good start.... can you get cams? IF so comp has some nice cams for 200 each
Chris
'02 Z-24 Supercharged
well running open header certainly wont help your midrange power but theres not alot of options maybe a 2.25 inch that might give you better torque than a 2.5
kick out as much weight as possible obviously as that will help you in pretty much every catogory, not sure but you may be able to make some gains porting the intake manifold a bit, some new injects are always a good thing i believe stock on those motors is 270cc, some 26lbers should do fine, run an msd ignition if rules allow, some nice gains can be made on the cylinder head
Low end? what's that? On the Ho, the peak torque is at 5200rpm so forget the 2.25 exhaust. Go 2.5". Stock injectors are 32lbs. Make sure you have the 086 head, 90-92 exhaust manifold and 90-91 small ho pulley.
Gilles
2.3 Ho
low end.... hahaahahha
my 10 speed bike ( when i was 12) had more ft\lbs than my LG0
Chris
