Not an electrician, so don't want to fry anything...  Need help to direct wire my radiator fan (bypassing the relay) to toggle switch on the dash for circle track racing...
Can I just go with two wire setup (power and ground) through the switch?  Any good diagrams?
Thanks,
Keith
with heavy enough gauge wire and a correctly rated switch you could go with a 2 wire setup
but i would highly recommend the relay option .. the fans at full rpm pull a decent chunk of power .. so the relay allows you to keep the heavy wires shorter and contained in the engine compartment ... then you can run a 2 wire setup to the switch panel on the dash
Anyone use a kill switch? Is so can you post what you used and how to wire it up. Not sure if I need it but couldn't hurt
Matt Bootsman wrote:Anyone use a kill switch? Is so can you post what you used and how to wire it up. Not sure if I need it but couldn't hurt
For what sanctioning body? Most of them are different. You will probably need to cut power to the ECM too which will require a different kind of switch.
