i will update this thread as the season goes on. 5/6/17 is our car show and first race. i still have to pull the blown engine, swap the transmission and put my other engine in. then finish up the fuel system and everything will get painted.
Car looks good man. Good luck to ya
beautiful build ... nice job
looks like an asphalt car so i gotta ask what are you doing for suspension
i just built a sunfire for our tracks new ministock division and its running well but i'm sitting way to high compared to everyone else
and at the moment she is tight in loose off so i need to make changes but i figure lowering it should be the first change
we have tried the edbach lowering springs in the past and the progressive rate seems to hurt us bad so was wondering what others are doing
We have to run stock suspension, Im still trying to figure out a stock spring that will lower the car a bit, but no luck. Are you running the rear with a sway bar?
Really the only adjustments im allowed to make is with sway bar sizes and tire pressure.
Put  lowering springs in. Just paint them black.
