alright guys...about to start the ole paint job on the 87 toyota supra.  me and a buddy are gonna do it ourselves.  we got a gun and everything....
just wondering what steps and procedures we should take to start.  (sanding, priming, painting, etc.)?  what order and how often and much
just looking for some advice...hopefully some expertise and experience...
thanks
well...if thats necessary then yes.   its a puke baby blue color and where its fading, its turning pale yellow.  im wanting to paint it neon orange i think.  just needing to know what all i need to do to get it ready.
to get a good job it's likely necessary
cause you gotta see if there is any damage, filler etc
lots of primer lots of sanding
lots of colour sanding
or earl schieb for $69
Adam Hand wrote:im wanting to paint it neon orange i think.
please no.  cars arent meant to be neon colors.
Andy
it's not how fast you go, it's how you get there that counts.
ZZP XP cam, 1.6 rockers, 105# springs, speedbuilt FWI, 3.3" modular pulley, TOG headers,
 3" exhaust, flomatched injectors
'97 GTP 14.06@100.6mph pre cam w/ 3.5" pulley, I/E
My biggest tip would be when you pick up the primer, surfacer, and base coat, and clears, make sure you get what is called a P-sheet (product sheet). It will tell you what you can mix and how you should mix stuff. As well as flash time and dry times. Its kinda hard to just tell ya how to paint. Soo much to it.
You might wanna look up self etching and acid based primers vs. epoxy primers. Very important to get those thing right because the paint wont last even if your prepping is done right. Certain base coats wont stick to some primers. Sanding in between coats of primer is very important.
Im by no means trying to discourage you from trying it yourself. Theres no better way to learn than by trying it. Just make sure you do your research or youll be wasting a lot of time and money. PPG.com has a lot of good information usually.
This is just an example of what you can find  one one of the primers
http://corporate.ppg.com/ppg/refinish/matthews/documents/mpc167.pdf
Good luck and keep us updated!
"Custom cars, custom problems."-me
thanks a lot guys..
especially you drew k.
thanks for the tips
ill keep you updated whenever ig et time to get it all started
