A couple of you guys wanted some more pics of the stang were building so here they are. It has a 577 CI stroker motor with a scat crank, eagle H beam rods, lunati pistons, 677 lift crane roller cam, Ford Dove c heads that have been fully ported and polished, Victor Jr intake, 850 Demon carb, triple valve springs and roller rockers. A motor similar to this one pumped out 725 horse, the only difference was he was using a different intake and a slightly smaller cam. The car itself has a 10 point cage, ford 9 inch rearend, kirkey race seats flaming river rack and pinion, sumped tank, and 5/8 braided line front to back. I know ive prob left out a bunch of stuff. The car should run into the 9's if we can get it to hook up on the 10 inch mickey thompson drag radials (not pictured) now on to the pics..
WOW! That is simply amazing.
So I take it your going to get a shaker hood.
"Remember do what you like because you have to drive it."--Me
holy batmans balls!
Two wrongs don't make a right. Unless you're Chuck Norris.
Then two wrongs make a roundhouse kick to the face.
lower the front, and keep the rear stock...that would look badass
SPONSORED BY: CAVALIER EXTREME
It looks like its sitting up high because its actually on jack stands. the pic of the car outside obviously has no motor in it.  A tranny crossmember is in the middle being fabricated because the stock on is actually to far back. The motor sticks up 5 1/4 inches above the top of the fenders, a 6 inch cowl induction hood has been ordered to cover it.  Ill keep you guys posted as progress moves along.
I don't like mustangs but that is @!#$in NIIIIIIIIIIIICE!!
nice. looks expensive.. can that run on pump fuel?
yes, it was built to run 93 octane
