transfer case stuck in 4 low.  replaced vacum switch and diaphram no results   any tips?
what gear are u in when trying to get out of it, i had an old k5 blazer and i had to be in park or neutral to get  back into 4high from 4low, then was in drive from going to 2 from 4hi
and i take it is  push button 4wheel drive?
yes it is push button,  the transfercase wont shift out of 4 lo
Might have to replace the switch on the dash werer you switch between gears. I have had it happen to one of my customers shortly after they purchased a blazer from me, except that they couldn't get into 4 wheel drive at all. The light would blink and then not switch over at all. That might work, and it is not that expensive, compared to replacing the entire 4 wheel drive set up.
http://www.j-body.org/forums/read.php?f=1&i=333805&t=333704#333805
The switch all the way.  Had a 2000 Blazer LT and had the same problem.
Modds:
GM Stage 2 with SFPHQ 2.8 pulley
Injen Intake
GM Dual Pass Aftercooler w15psi Surge Tank
GMPP Exhaust Manifold
CTi 3" Downpipe and Cat
Custom 3" Cat Back with Dynomax Super Turbo Muffler
ZZ Engine Mount
ZZ Front Trans Mount
B&M Shifter
NGK BKR7E Plugs
DC Strut Tower Brace
Soon to be installed:
2.6 pulley, Siemens 60lbs Injectors, NGK 2 Step Colder Plugs
Tune Time Custom Dyno Tune
Hey, sorry to steal your thread Nate, but on my friend's 99 trail blazer none of the lights come on! and nothing happens when the buttons are pushed. I told him it might be the Switch. You guys think that's what it is? sorry for not starting another thread!!!
stock '00 2200 cavy
My dad had a similar problem on his 98 Chevy S-10 only he couldn't engage 4x4. He was planning on taking the truck to a repair shop so they could fix it. I was installing a CD deck in his truck one day and had to disengage the switch for his 4x4 so I could move the dash plastic around so I could work. When I plugged the switch back in to the button his 4x4 mode was fixed. Maybe you could try that before dropping alot of money on a repair?
Blown.
Yeah, the switches on the push-button cases are @!#$. Same thing happens to my parents '99 Silverado.
<A HREF="http://www.cawpin.com">
<IMG HEIGHT=100 SRC="http://www.cawpin.com/images/carpics/thumbs/Jeep_new_04_th.jpg"></A>
its probabily the motor on the transfer case itself, I had the same thing happen on mine I picked one up on ebay for about 40. Those are nitorous for the motors going bad.
thanx guys , brandon thats where im at  peace
Either the switch, solenoid or motor is the problem.  My guess is the switch as said earlier, if it isn't the switch then the next thing would be the solenoid.
Yella02-I promise I will return to you in one piece and this will stay up until I am safely home
