Because traction is slightly limited.
The tires were 'donated' by a friend. Nitto 555r streets with good tread.
http://home.comcast.net/~mrluosss/streets.wmv
Only the gas pedal was used in first. Clutch was fully engaged.
Honestly, while it is fun this way, it isn't safe. I could feel that they wanted to break loose if I was in 3rd gear around 4500 and I punched it. That is moving around 60 MPH. It would bark them HARD into 4th gear at 85 MPH too. And that wasn't taking it to redline in 3rd.
________________________________________________________________
1999 Pontiac Trans Am WS.6 #1747
527.0 RWHP
469.0 ft/pounds
A short video of "Slowass"
hmmm, need more power.
I wrote this post a long time ago, a real long time ago, back in 94.
NICE. mine like to spin alot too(damn stall converter) but its not that bad...
WOW, thats amazing man,
sound and power
Nittos arent very sticky for DRs. Get some used Mickey Thompsons for a better 60'.
05 M6 YJ GTO 1 of 447
Emor8t wrote:hmmm, need more power.
i agree with emo8t
you need some more power
then it'll be a beast
Two wrongs don't make a right. Unless you're Chuck Norris.
Then two wrongs make a roundhouse kick to the face.
Sappy96 wrote:Nittos arent very sticky for DRs. Get some used Mickey Thompsons for a better 60'.
I have cut a 1.868 on the Nitto DR's. I have a set of M/T DR's here (275/50/15's) to run the next time I am out.
The footage was taken running 275/40/17 Nitto 555r street tires. Not the DR's.
I run the 315/35/17 Nitto DR's on the street. They actually hold the street pretty well, just aren't the best at the track.
527.0 RWHP
469.0 ft/pounds
So what is it running at the track these days?
5pointO
Must be nice to fit that wide of a tire under there.
x2 unless you're still running your 10 bolt
Lash wrote:So what is it running at the track these days?
Best to date....
12.324 at 115.55 MPH.
Density altitude was 8500.
527.0 RWHP
469.0 ft/pounds
thats it ^^^ WTF is up with that... how does the altitude change it??
Basicly works the same as any track.
The Density Altitude goes up as conditions get worse.
The hotter it is, the higher the density altitude.
The only problem I have....mine starts at 5800 feet. That is Bandimere's actual altitude.
I used a DA calculator I found on F-Body.com and corrected that 12.3 is roughly a 10.8.
527.0 RWHP
469.0 ft/pounds
lol That was just nuts.
I think you better retrofit a AWD in there.
>>>For Sale? Clicky!<<<
You don't need awd, just some slicks.
Mr. Luos wrote:Basicly works the same as any track.
a 10.8 is a little better
i knew that the altitude made it worse but wasn't sure how much.. but yeah get some stickys and if you havent already a really REALLY strong rear end
Moser 9" is installed.
I have soem M/T DR's waiting to test out. Soon.
527.0 RWHP
469.0 ft/pounds
that thing is nasty
-Borsty
