Help! My b16a needs a... - Other Cars Forum
Thursday, October 26, 2006 4:51 PM
I still have the cav, but I just bought a civic and did a b16a swap but I only have the origanal ecu. The question is what year and model has the computer I need and how many others can run this motor? I know reaseach it, thats what you all will say but help me out just this one time. please!
http://www.cardomain.com/ride/2366291
Re: Help! My b16a needs a...
Thursday, October 26, 2006 4:52 PM
I know the del sol does but I can't find one here in town.
Thursday, October 26, 2006 4:56 PM
http://www.honda-tech.com/
i dont know, but this is great web-site
Thursday, October 26, 2006 5:01 PM
If you would post on http://www.honda-tech.com you would probably have an answer in about 5 minutes.
I used to find a lot of info on there when I was going to swap a B16 into my EF hatch. I ended up selling it though.
Rob
Sold 2/2/05
Thursday, October 26, 2006 5:03 PM
Thanks, but I took the time to search it but they don't really exactly pinpoint the answer.
Thursday, October 26, 2006 5:10 PM
Thursday, October 26, 2006 5:14 PM
93-95 crx/del sol vtec ecu # p30
99-00 civic si ecu # p2t
heres the site
i cant really make sense of it... maybe you can....
took like 2 sec.
Thursday, October 26, 2006 8:15 PM
You'll need a computer for that year model of the engine. So if its a USDM motor then yes you can find it here. IE the Del sol has it in mid 90's or 99-00 for the Si. However if its a different year model then its going to be a JDM engine. Seeing how the Civic in the early 90's didn't have the b16 engine. So you'll have to order it off line more than likely. Hence why most the time you buy an engine it comes with a ECU.
Saturday, October 28, 2006 12:50 PM
Yea I know, this sux. I done with it and can't even hear it purr. Anywayz go j-body(lol)
Saturday, October 28, 2006 1:03 PM
Gonna need the harness too, unless you want to rewire the one you got. And if it's a VTEC, gonna need to wire the ECU for that, too. I'm not gonna ask why you did the swap without knowing what the engine came out of but you might be smart to pull the VIN off the block and take it to the local Honda dealer. Maybe they can tell you what car it came out of.
Saturday, October 28, 2006 4:42 PM
Or you can look on the block. b16a2 = USDM engine out of a 99-00 Civic Si. B16A1 means JDM or vice versa. Dont listen to me just look it up.
Monday, October 30, 2006 10:04 PM
depends on what year your motor is.
88-91 u need the jdm b16 ecu. obd0 and it will fail smog due to too high of NOX levels.
92-95 b16 you can use the jdm SIR b16 ecu which is obd1 or u can use the 93-95 del sol b16 ecu. again the jdm will fail for high NOX levels.
96+ you can use the jdm ecu or the 99-00 civic si ecu.
you can also use according gsr or type r ecu's for those years.
high NOX levels are usually due to high compression motors. and since the older motors most likely have carbon build up. the compression is even slightly higher.
any local import shop in your area should be able to get you a jdm ecu for under 200 bucks.
wiring the car for vtec is easy and only requires 3 wires.
http://www.myspace.com/15102113
