Hi,
 I have a 94 Honda Prelude si, I was tring to turn the steering wheel with the car not running, when I did that the steering wheel turned about half turn and made a grinding noise from down near the steering rack or the steering shafts,  but the wheels didnt turn.  now i can feel the steering wheel / shafts / linkage lsip and grind if I try to turn hard.
I want to know if this common and also if there is an adjustment where i can tighten something up to fix this or what. or any other info would be great.
thanks in advance!
*j*
My car was made with wrenches, Not chopsticks.
Well im thinkin its the teeth on the input shaft on the rack, I was hoping that it would have some kind of collar or a bolt that could be tightned. sounds like i will be pullin the rack this weekend, I found a used unit with all the shafts at a local salvage yard, my car only has 80,000mi on it and the used rack im getting has 62,000mi on it. hope thats all it is.... maybe i will get lucky and and it will be just an adjustment, Im going to put it on a lift at work tonight and take a peek at it. lol
thanks
*j*
hahaha just got lucky!!!!!!!!!  there is a coupler joint in between the steering rack & the shaft.  it was just loose, there are 2 bolts on each side.  i tightened them up and its perfect!
im happy!
thanks again.
*j*
I was just excited!    lol
