Does anyone know of any sites similar to this one but for yukons? Specifically Denalis?
My friend is trying to do some research on lowering/ levelling his Denali.
Thanks
yes try chevytruckworld.com you might find some help there..........
Seeing as the Denali is simply a luxury options package, I'd think that most everything good for the base Yukon would work for you as well.
Shop Manuals, Brochures:
www.kenmcgeeautobooks.com
Geeky wrote:Seeing as the Denali is simply a luxury options package, I'd think that most everything good for the base Yukon would work for you as well.
I thought denalis had auto-ride...... i dont know if the base models had that option it might be a problem
Autoride is a fully automatic ride control system that continually adjusts
the damping level on each of the four individual shock absorbers to provide
superior ride quality and handling performance. Autoride's "tow/haul" mode
helps improve vehicle body control while towing and hauling by offering
increased levels of damping. Also included with Autoride is automatic rear
level control, an air suspension system that helps keep the vehicle level over
a wide range of passenger and loading conditions while also maintaining rear
ride travel.
Autoride Operation
Autoride uses an electronic control module (ECM) to continuously monitor
brake, throttle and steering inputs as well as vehicle body and wheel motions.
Using this data, the ECM can maintain optimum ride quality by separately and
electronically adjusting the hydraulic fluid flow through the valuing discs in
the shock absorbers. This results in enhanced body control motion and a
pleasing, refined and well-isolated ride.
Stephen wrote:I thought denalis had auto-ride...... i dont know if the base models had that option it might be a problem
You know what, now that I think about it I've see that system in action. Good call. I retract my previous statement.
