I was woundering if a rsm ecotec cavalier supercharger stage two will fit a cobalt.  I just recently bought a cobalt and realy want to boost it.  Thanks
Since the Cobalt has electric streering, the kit had to be remade.
The blower sits on the other side of the motor for this platform.
The good news is that we can push the V9 much further.  if you have the need to push tons of air...no problem.  The limitations of the J body kit are not relevant for the Cobalt.  We can make the pulleys much smaller on the other side of the engine.
Craig,   In the event when I someday get your Stage 2 will I get a little discount since I have Venom Fuel injectors ( not installed yet). And also,  I haven't read about your SC for a while.  Do you guys put  on the 62mm TB?  And if so would I get a further discount since I already have it? and one more question I ahve your crank pulley, when you put the pulleys on for the SC is the pulley replaced when you install the SC?
There is no Stage 2 for the cobalt.  Like I mentioned before, we can push the Cobalt package further because the accessory driven system runs mush faster.  A smaller pulley can be used without the risk of excessive slip.
With the increased boost...the need for bigger injectors is obvious.  I have no experience with Venom injectors.  I have been told they are the wrong impedance.  Without direct experience with these, I cannot comment any further.  I would prefer you use our injectors.  We can guarantee compatibility and proper function with our re-flash.
We certainly can supply you with a ported head for the cobalt.  I'm sure we can work something out if you are buying a number of products at the same time.
The throttle body for the cobalt we have is electric.  Meaning it is opened with a servo.  We are still developing the unit.  Getting the thing apart without damaging it has proven to be problematic.  We can do it, but the labour involved will make the price very high.
If I recall correctly, we need to put a different pulley on the crank for the cobalt kit.  The current unit would not be compatible.
I hope I made sense.  I havn't had any coffee yet this morning.
the venoms are susposed to be 10% larger than stock , not big enough for alot of boost
Sorry Craig I should have specified  I have a 97 Z24
I'm a little confused.  You want the kit for the Z or the cobalt?  The kits are entirely different.
Craig Lewis wrote:I'm a little confused.  You want the kit for the Z or the cobalt?  The kits are entirely different.
He wasn't the creater of this thread, he just jacked it
<img src="http://thespork.dataride.com/theorg/sig.jpg">
Visit The Spork
