is it possible that a bad BCM or other module besides the PCM could cause a connection problem with HPT?
the HPT gauges work no problem. there are some DTC's, but I can't think of them off the top of my head, and I don't have the list in front of me.
Desert Tuners
what exactly do you mean by connection problem? are you not being able to connect to the car in editor? in the viewer? what type of problem are you having?
i cant see i bad BCM giving you a connection problem as it should have nothing to do with the actual running of the car. the BCM just controls things like the fog lights and the door chimes.
1997 RedR - ZedR
we cannot connect to the car in editor, at the part where it says "gathering information". we can however get the HPT "gauges" to work.
Desert Tuners
check all your grounds, and also wiggle the back of the ALDL.. I have a customer's car here giving me a similar fit...
P&P Tuning
420.5whp / 359.8wtq
Also make sure only one program or the other is open. So either the scanner or editor not both.
here are some codes we have been getting
[Restraints] B0036 - ADS Open/Missing/Shorted to Battery (History) (Immature)
[Unknown] B2662 - Unknown (History) (Current) (Immature)
[Unknown] U1128 - Loss of Communications with IRC (History) (Immature)
[HUD] U1000 - Class 2 Communication Malfunction (History) (Current) (Immature)
If I'm weird and everyone else is weird, does that make me normal?
-me
Versus Motorsports really @!#$ sucks
and so does DHL...but more
