Gettin ready to bumb the 16G intercooled setup from 5 to 10 psi this weekend. I will be tuning with HPT and LC-1. Dropped the cash and have been reading everything lately. I am running a FMU and stock inj's now. I have a set of accel 32's I think are gonna be big enough...What do you guys think I should do with my fuel setup??
with 32lb injectors and hpt you should be fine... i ran 15psi on 42lb green tops so 5 on 32lb sounds ok... you dont need the fmu though, if you get a 2bar map sensor you can use hpt to tune the car without a fmu
i ran 17psi on the stock pump, my only fuel mods were injectors, hpt and a wideband i believe...
I am going to be at 10 psi.
Stock fuel pressure will be cool.?
Hmm forgot about a map sensor...guess Id better start looking.
