ok my question is, does it really worth the price to buy hpt pro instead of standard one? i read about the difference but for me it's not really clear.. i meant can i tune car correctly using hpt standard??  what are the difference??? i'm not sure wich one to buy...
 http://cavalierdomination.monchar.com
yes i read the fact but i would like advice from guys that use normal ou pro hpt! because only things i found were that the pro version can read device like EGT and wideband in real time but if i use external gage do i really need to pro! you know i just dont want to pay for something i dont really need!
Yes, if you want to tune it correctly. Read the VE tuning FAQ and imagine trying to figure out those numbers without a wideband. The wideband into HPT puts the data in at the right places in the logs so you can catch those short lean spots without somebody writing down what RPM/MAP/TPS you are at when you hit a lean spot that only lasts for 250 RPM. Honestly if you want to tune your car correctly and safely, then HPT pro is the only way to go.
 4cyltuner.com
It's worth it.
15.3 @ 89.97mph - '01 SFGT
'98 Acura 1.6EL Sport 5M Y7/Y8 mini me
