I am reviewing a product that my parent company wants to help fund.
It is Corsa EZ-Logger.
I was wondering if anyone has heard of them, and what is any experience you have had with them. I have a sample package sitting in front of me. It seems to record a lot of data.
They also make a product called...
IntelliDash
IntelliDash display features:
* Peak hold and recall on RPM, pressure, temperature
* Engine RPM (digital and graphical)
* Pressure (oil or boost)
* Temperature (water, CHT, or EGT)
* Battery voltage (low, OK, high)
* Vehicle speed
* Display flashes if reading is out of limit - high temperature, low pressure
Programmable Features:
* Tach red line
* Alarm for high temp, high/low Pressure
* Shift light output
Just seeing what you all think.
^^^^That is almost word for word what I told the president of my company yesterday. He didn't seem to pleased.
I just wanted to make sure I was not off base.
I think you can do alarms with HPT E I/O ports (through LEDs), I would like one for over boost as well as knock retard, but haven't had time to play around with it.
Mitsu TD06-20g |3" Downpipe w/ Cutout | 61mm Bored TB |
HP Tuners | Innovate WB02 | Spec Stage 3 | TurboTech Upper | Full Addco Sways | Sportlines & Yellows |
BlackEco wrote:I think you can do alarms with HPT E I/O ports (through LEDs), I would like one for over boost as well as knock retard, but haven't had time to play around with it.
Yep there are 4 outputs i think.... i think relays may be required tho. I was thinking about putting an LED in my stock cluster by the tach as a shift light
only problem is... i would have to have hpt hooked up to use it.
Not sure what your purpose is, but there are other products which will plug into an OBDII port to log data. What I've sometimes found with the expensive racer designed products is they're built for a guy that doesn't want to waste time getting too technical, so when you want to do something a little outside the box with the product, it can be tough to get it to cooperate.
-->Slow
^^^ Its not for me, just investors at work were looking into purchases or financing Corsa.
