Emanage Showing Wrong RPM? - Tuning Forum
Wednesday, June 22, 2005 3:38 PM
I heard there was a way to fix the rpm reading half on the emanage.... Any help would be apreciated...
Kris Bloom
Street Challenge
http://www.streetchallenge.info
Http://www.streetsourcemag.com/projectz/ <--- The Cav
Re: Emanage Showing Wrong RPM?
Wednesday, June 22, 2005 4:02 PM
did you originally not have a tach? you will probably need RK Sport's tach adapter.
Wednesday, June 22, 2005 7:21 PM
no it is a 2.4... it has a stock tack. I heard there is a way to wire the emanage so it reads the correct rpm
Kris Bloom
Street Challenge
Wednesday, June 22, 2005 9:32 PM
There should be a full tach signal on your engine bay fuse block.
This has been answered numerous times. Not to rag on you but please do a search next time.
Thursday, June 23, 2005 12:18 PM
i DID do a search.... got 25,000 emanage posts and none of them answered my question... so if you can post the link to the thread that answers this i'd apreciate it...
Kris Bloom
Street Challenge
Thursday, June 23, 2005 12:47 PM
Look at the cover over the fuse block in the engine bay. There is a lead that says "Tach"... jam the bastard in there and you're good to go.
I got a full tach signal for my S-AFC I there.
-Chris-
-Sweetness-
-Turbocharged-
Thursday, June 23, 2005 7:58 PM
well, i want to do it right, theres a wore coming out of the ecu that i need... just don't know which one...
Kris Bloom
Street Challenge
Thursday, June 23, 2005 10:05 PM
That is coming from the wire out of the ECM.
That would be the black connector, number 10 slot.
O noes!
Wednesday, July 20, 2005 6:27 PM
do what? lol... I think you know the answer but could you explain.... black connector? I'm dealing with a series of colored WIRES coming out of the ECU...
Kris Bloom
Street Challenge
Wednesday, July 20, 2005 7:21 PM
Yes, if you take the connectors OFF the ecu (which you'll have to do), and you look at the black connector, its Pin 10. Simply tap that wire coming out of that pin (if you want a more detailed description, visit http://www.ny-jbodies.org/library/library.asp ). That is a full tach signal.
Other options you have are to set the E-Manage to a 2 cylinder vehicle (not sure if you can) or buy a tach adapter. If you have a 99, that pin might not be in the ECU (there will be no wire coming out of Pin 10 on the black connector), and you can simply insert a wire in there and it will work.
Wednesday, July 20, 2005 8:49 PM
none of the links in the library work for the 97 2.4L
Kris Bloom
Street Challenge
Wednesday, July 20, 2005 9:32 PM
Personally I use an MSD DIS tach driver under the hood. Two wires go into the ignition module, a ground, then one goes back to the e-manage. I know thats more work but oh well... works just great.
