I did about 45 mins of logging and I have a very vague idea of what to do with every thing. Can I can send my tune and histgrams if anyone cares to takea look  and see if they can improve on it.
Thanks in advance...
I forgot to add its a ld9 2.4 .04 over 10 cr pistons, polished head 1mm oversized valves, cams 415L 219 dur intake 390L 206 dur exh. 58mm tb, balancer delete kit, ho pully
your cmd AFR is all over the place at WOT so before you do anything else  i'd double check your injector constant. What size are your new injectors? if they aren't the stock ones.
injectors are stock right now.
ok that issue was fixed I had my math backwards. I set my afr to about 12.7 from  3600 to redline 12.7/13=.97656.... IS my new mulitplier
Labels	1200	1600	2000	2400	2800	3200	3600	4000	4400	4800	5200	5600	6000	6400
PE Mult	1.00000	1.00000	0.99219	0.98438	0.98438	0.98438	0.97656	0.97656	0.97656	0.97656	0.97656	0.97656	0.97656	0.97656
This is more consistant then the way I had it before.  Is 12.7 a pretty good afr or should I add more fuel?
12.33 @ 111.67 mph [Oct 2009]
327.6 WHP  333.6 WTQ [10.1 AFR]
now I need to figure out spark advance. Anyone have any knoweldge if which way I should go with it?
i updated my tune if anyone cares to take a look
ok i'm not looking for handouts but a starting point. I dont know exactly what I should do to tune the timing. Ive been reading on here and hp tuners forums and I havent found anything that really explains it very well. I'm just looking for push n the right direction. Thanks
Have you tried Shifted's VE Tuning
Sticky at top of this section
 Are the steps for ve basically the same for timing? Do you copy the scan tables to your editor?
