PLEASE READ MY WHOLE THREAD BEFORE DOWNLOADING / USING THESE BASE MAPS
USE THESE ARE YOUR OWN RISK I AM NOT RESPONSIBLE FOR ANYTHING THAT HAPPENS TO YOUR MOTOR! USE AT YOUR OWN RISK!!!!!!
/disclaimer
THESE
BASE MAPS ARE FOR MEGASQUIRT MSnS Board Version 2.2
Used WIth MegaTune2.25b271 Software.
These Are Also FOR THE 2.2 ECOTEC Engine, It MAY work on other engines but will need Modifying. THESE MAPS WILL NEED TO BE TUNED BUT IT WILL GIVE YOU A STARTING POINT. I STRONGLY RECOMMEND THE USE OF A WIDEBAND 02 SENSOR TO GO BY WHEN TUNING OR WHEN 'TESTING' THESE MAPS. IF YOU ENCOUNTER LEAN CONDITIONS PLEASE TUNE ACCORDINGLY.
Ive Been Getting Alot of Emails / Private Messages For my base maps for the megasquit so here they are:
http://djclueless.automotivelifestyle.com/ms/
-They Are Labled as Orlando-T Cause My car was being Tuned On the way to orlando from miami for the 6th Annual Florida Meet At Race Rock.
Anyways These Are Just Base Maps And Were Tuned Based On:
-2.2 Ecotec
-550cc HIGH Impedance Injectors
-~43 Fuel Pressure Idle ~53 WOT WIth a 1:1 aFPR.
-62mm Throttle Body
-60-1 Turbo
More Information On MegaSquit Can Be Found Here:
http://megasquirt.info
Ill Also Add That if anyone has any other maps they would like to share Feel Free to Post Up. Also when sharing these maps please give me some credit Thanks.
-DJ
Thanks bud. Sorry I kept nagging at ya forever for them.
What kind of boost were you running with these maps?
Thanks again, this is really generous of you since you are one of the only megasquirted ecotec I know of.
Major props,
Thanks.
"Go Before Show Yo."
CARCUSTOMS.NET, THE BEST SERVICE ON THE ORG!!!
those maps were good for 7-9 psi
the higher the number was the lastest map i used..
-DJ
Maybe I should get these maps for my 2.4 so I can have an idea where to start with the thing, I know I will love the megasquirt but wow I am afraid of two things: Ignition wiring and tuning.  Base maps would be awesome!  Someone need to host all of them we have for our cars with decriptions!
So I say it shall be true.
22 miles per gallon and dropping fast...
