Wondering about fuel tables for a 1998 LN2 in hptuners.  Do they have the injector flow rate tables? Im getting ready to install 50lb delphi injectors. How about cranking fuel at startup? I know that they dont have nearly the parameters that they have for the Ls1 engines. I know this pcm is pretty lame and not much support for it.  Thanks
injector constant
ve tables
ummm that bout sums it up on our platform
Your WHAT hurts?
ok thanks. Im looking at efilive's table for the ln2 and I dont see anything for setting up the injectors.They have PE, and VE but Im not seeing anything for setting up the injector size for the engine. Thanks
tom jones wrote:ok thanks. Im looking at efilive's table for the ln2 and I dont see anything for setting up the injectors.They have PE, and VE but Im not seeing anything for setting up the injector size for the engine. Thanks
The tables between the 2 programs are very similar.....
P&P Tuning
420.5whp / 359.8wtq
WHat is efilive using to setup the injectors? Do you know the name of the table?
I dont think their is a injector flow rate table in efilive, at least in the tune tool. It may be in the scan tool.
QWK LN2 (needs an @ss whoopin) wrote:tom jones wrote:ok thanks. Im looking at efilive's table for the ln2 and I dont see anything for setting up the injectors.They have PE, and VE but Im not seeing anything for setting up the injector size for the engine. Thanks
 Do you have efilive? Can you confirm the tables are similar? Thanks
tom jones wrote:QWK LN2 (needs an @ss whoopin) wrote:tom jones wrote:ok thanks. Im looking at efilive's table for the ln2 and I dont see anything for setting up the injectors.They have PE, and VE but Im not seeing anything for setting up the injector size for the engine. Thanks
 i used to have EFI Live and I have seen the tables.  They are almost exactly the same....
P&P Tuning
420.5whp / 359.8wtq
What did efilive use to setup the injectors then? What was the table named?
tom jones wrote:What did efilive use to setup the injectors then? What was the table named?
 Should be labeled the same as HPT... Injector constant....
P&P Tuning
420.5whp / 359.8wtq
tom jones wrote:Nah its not there.
Can you give me a screen shot?
P&P Tuning
420.5whp / 359.8wtq
