Anybody have find how to tuned VE DownCoast ??? I try many histograms with 2.22 & 2.23(beta) version and no one works...
Thank
Boost Lover
What OS is your PCM/Flash.  BTW, Fill out your damn profile/mods page...
P&P Tuning
420.5whp / 359.8wtq
QWK LN2 (P&P Tuning) wrote:What OS is your PCM/Flash.  BTW, Fill out your damn profile/mods page...
2003 Cavy L61T, Map 1 bar, 60 lb/hr injector. Need to tuned my downcoast VE with my Hp Tuners
Boost Lover
You need to log manifold vac its a different pid than manifold absolute pressure. Dont forget to have it exclude throttle over 1 and speed under 1.
Sponsored by:
Kronos Performance
Thank ! What is the target AFR in Downcoast (VSS) table ???
Boost Lover
target afr will be 14.7:1 unless dfco is enabled then target afr is 99999999999999999999999999999999999999999999:1.
Well technically hpt still displays 14.7 as the afr cmd but the car has just shut the injectors off.
Sponsored by:
Kronos Performance
Then, i don't need to tuned VE DownCoast... just put all value of table to minimum (VE offset value) ? if the injector duty cycle are 0.000ms during DFCO !
Thank
Boost Lover
NO!
You need to disable dfco and time that table like any other.
Sponsored by:
Kronos Performance
