Help i Have a 1999 Motor with a 2001 ECU - Tuning Forum
Thursday, June 02, 2005 4:05 PM
COULD THE DIRRFRENCE IN YEAR BE CAUSING MY BACKFIRE BECAUSE THE CAMSHAFT WAS CHANGED IN 2001.Are the ecu the same?
Re: Help i Have a 1999 Motor with a 2001 ECU
Thursday, June 02, 2005 6:10 PM
No they are not the same. The camshaft and cam sync position changed in 2000. Basically using the '99 motor with an '01 ecu will throw off the computer and cause it to fire the fuel injectors at the wrong time, which is why the motor is running so crappy.
Thursday, June 02, 2005 6:18 PM
Hey man were did u find your info. Ive been trying to figure this out for three weeks now and that the problem its like im getting to much fuel.
Thursday, June 02, 2005 10:48 PM
my friend is running a 02 motor in his 97 , with a 99 program in his cav and no problems
Thursday, June 02, 2005 10:49 PM
Like I said in the e-mails, the computer uses the camshaft to sync up the fuel injectors.
Friday, June 03, 2005 9:38 AM
Hey 97 cavie is your friends a 2200 or a 2.4?
Friday, June 03, 2005 11:04 AM
Cracker Rocket,
Where did you find the info about the cams changing in 2000?
275hp & 306tq - 1999 2.2 ohv
13.2 @ 108 mph
-1996 2.4 liter + Turbo + Built motor + Torco + More boost = Lots o' Power
-2000 Mustang GT + 2004 Cobra motor, Whipple 2.3 supercharger,
built rear-end,Dodge Viper spec T56 6 speed, bolt-ons = wheelies at the track!!!!!
Friday, June 03, 2005 5:07 PM
It was a while back that I was told that the 95-97 and 98-02 motors had different camshafts. From what I understand, the 98-02 motors all had the same grind, but the cam sync was changed between 1999 and 2000. Thats why it would be throwing off the computer and fuel injectors, which might be the cause of his fuel issues. Oh, and if I remember correctly, it was a parts guy at the local chevy dealership that told me this.
Friday, June 03, 2005 5:37 PM
Hey i picked up a 99 ecu put it in the car tries to turn over but wont start doesn anything have to be done before starting the car or is the ecu no good?
Saturday, June 04, 2005 1:42 PM
If they changed the cam sync in 2000, I wonder if they changed anything on the crank position sensor on the 2000's.
13.2 @ 108 mph
