hello everyone i am currently have some trouble with the super charger reflash i am running t28 turbo 36lb injectors secret cam swap
the problem.... i bought the reflsh from hp tuners i flash my car and now it doesnt start the 2 bar sensor i am using is gm #12580698 . if i pu the original 1bar it starts and idles but thats it has no power. yesterday i installed back the 2bar and rised the fueling ve tables and it started but if i turn it off and leave it sitting for about 15min it will refuse to start anyone please help
Truly sounds like you do not have a true supercharge reflash.
If it was a true charger reflash the car would not run on the 1 bar map sensor.
I got the tune from the repository on hp tuners ill post it up so u can take a look at it
Is it one of the ones I posted?
If so...MANY people have used it.
no its not i used garret janzen tune i figuered since his car is the same year and manual trans
I compared that one to the one I downloaded by Shifted, there are minor differences, nothing that should keep you from starting.
It's also possible you got a bad sensor right out of the box, if you didn't get it too long ago you might be able to exchange it to rule that out as a possibility.
Okay so I got the tune to work turns out that the injector constant was changed when I downloaded it but now I have another problem after running with the reflash for about 3 weeks yesterday the car decided to play stupid and now when I boost 5psi the cuts out and starts backfire
