anyone have a bin of the 95 ecm? and what ever def files are available
i have a 95 cav 2.2 ln2 that we race on an 1/4 banked asphalt oval
have 3 races left for the season and i need to get a little more out of it due to a tight points race
i currently have the moates memcal adapter, a moates burn2 chip burner and 2 spare chips
problem is using tunercat to read the bin from the chip seems to work but when i open it i get the message i should be using a $cd def file instead of the $36 that i purchased from tunercat
also all i want to do at this point is read the chip and burn it to a new one with no edits and get the car to start with the moates g1 adapter (chip and memcal installed)
so when i just burn that bin to the new chip and drop it in i get no fuel pump priming when you turn the ignition and it doesn't start
i have also tried tunerpro rt with an $36 file i found somewhere and when i read the chip in that and look at the tables there all 0's
I’ll be happy just getting the stock bin running on the g1 adaptor
i know i have read the old threads where a couple ppl were working on this stuff but none of them seemed to come to fruition
Help!!!
