The newest update took care of both my limiters...... 7400 never sounded so sweet
once I get my dc/ac inverter working, I'll get some screen shots up......
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
Sweet thats great news, so it was really an issue with the traction control after all? lol
speed, you talkin about version 2.1.11beta or is there an even newer code out there??
Big question I have is can the stock internals rev that high, and are you actually making any power going that high??
DayUSeX (ws6+04cav= FTW) wrote:Big question I have is can the stock internals rev that high, and are you actually making any power going that high??
will you? probably not. but i take it you haven't looked at the mod list in SRZ's registry....
Arrival Blue 04 LS Sport
Eco
Turbo
Megasquirt
'Nuff said
Great news Brian.
Now the question remains: what are you going to do about timing and fuel past the stock 6400 map if you can't do anything about the values between it and your new 7400 rpm redline?
-Chris-
-Sweetness-
-Turbocharged-
yeah.... brians car is a wee bit far from stock....
congrats. kinda wishing i woulda went with hpt instead of the gm reflash.. wonder if they will ever make it work
John H [Cavalierkid wrote:]yeah.... brians car is a wee bit far from stock....
get a spare ECU (flashed for your car) and use HPT on that..
I have to data log it yet, to see how its running that high..... but it pulls just fine. Time to call the dyno up
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
i've added the spark ramp out and the traction control high rpm/mph fuel cut params to all the 4cyl calibrations now so if you download the newest 2.1.11 beta tomorrow they will be there. If not try the next day.
In any case the 2.1.12 release is scheduled for the weekend/Monday.
Chris...
Nice!
So i see your are using HO valve springs. Didn't the motor rev ~7200? Or was able to with stock valve train? So ur pretty safe. Mm.. hope a couple of guys test out the stock valve train on a ld9
Nate
1995 Cavalier W/2k1 Engine
listening and watching this.....
C24s/c wrote:Nice!
Nate
I will do it if you want to start a funding program for me to rebuild my motor when it goes boom.
Now Powered By TEAM GREEN
boost will be soon for me....
Sweet!! I still need to test that on my car. Damn syncro and rear main problems came up before I could test that
Jason
99 Z24
Racers Edge
Johnny Mack Turbo Systems
Engineered Performance
oh I'm pretty sure the stock valvetrain is good for 7200rpm.
sig not found
protomec wrote:oh I'm pretty sure the stock valvetrain is good for 7200rpm.
In your opinion are there any stock parts that aren't? Oil pump, etc?
oil pump is out of RPM when the engine crosses 6k. (2.4lt)
Watch a decent 270 degree sweep mechanical oil pressure gauge and oil pressure will begin to fall above 5800.
sig not found
Just wanted to report another success. HPT is able to raise the rev limit and speed limiter on 98 auto 2.4's now as well.
- 93 mph in the 1/8 mile
Member of J-Body Of Michigan.
sweet hows it feel shifting that high with the auto ?
Feels the same as before, only faster now.
The engine is still reving up faster than the trans can shift just like it did before. The shift point is currently set at 7,000rpm and the rev limiter is set to 7,200rpm, its still managing to hit the limiter before @!#$fing but the results are usually just a small backfire at worst, never stops pulling.
Good stuff Jeremy.
Is this the same Auto you had in last year that you were having problems with?
-Chris-
-Sweetness-
-Turbocharged-
Yup, same one. Haven't had any problems since. But then again i haven't tried to race it on a track back to back runs in 90+ heat since either.
Hows the "500+ WHP in Summer 2006" working out for you?
Protomec, what about the oil pressure falling off with the 2.3 swap? I would like to raise my rev to 7 with only ss valves and cams, but like Chris said, what are you guys using to tune between the stock cutoff and the newly set limit?
Blew it up, build numbers coming soon
SpeedRacerZ wrote:The newest update took care of both my limiters...... 7400 never sounded so sweet
It sounds awsome and good lord does it pull!!!!!!! next time I will know what to expect when I go for a ride for you and to not ride with you ona full bladder
