HPT on timing, WTF??!?!?! - Tuning Forum
Saturday, January 06, 2007 3:22 PM
I posted this under my "boost" thread too, but for those who only read here... I need some help..
ok, lets look over these timing tables, I have zero (0) in all the tables where I am running into boost, and all the multiplers at 1.0.
I understand my wide band reads 13-14, but the gauge and the AEM preset are about 1.2 off, and the sensor is about 6 month old bosch so those readings are incorrect. The actual AFR is about 11.5-11.7. Having said that you would think anytime I would be in the
HO (pe), LO (pr), HO (pe) alch, or LO (pe) alch, I should be running ZERO timing..... well lets look at this..
we were trying to pull timing and noticed that none of the numbers added up, so either you can't actually change the timing or I missed a window somewhere, could some one please enlighten me, thanks,
-Garrett
Re: HPT on timing, WTF??!?!?!
Saturday, January 06, 2007 7:17 PM
read my reply to the other thread....
Wednesday, January 10, 2007 7:42 AM
http://www.hptuners.com/forum/showthread.php?t=9697
it looks like they are going to fix that issue for me too, so I will post up when I get some results, usually with these guys it takes a day or 2, but I will keep you posted.
Sunday, January 14, 2007 8:46 PM
they have an update out, hopefully that will fix the issue, I will keep you guys informed when I get home to try it out "VCM Suite 2.1.15 Beta"
Sunday, January 28, 2007 7:12 PM
2.1.16 is out with this fix
Friday, February 02, 2007 1:15 AM
I downloaded 1.1.16..... Guess I'll have to play with it tomorrow
SPD RCR Z - '02 Z24 420whp
SLO GOAT - '04 GTO 305whp
W41 BOI - '78 Buick Opel Isuzu W41 Swap
