At idle my TPS reads 9. Under WOT it reads anywhere from 82 to 90. Is there anyway to adjust this? Shouldn't it be reaching 100% throttle? Is this a big deal or will it not really have any affect on anything? Thanks
it takes away some resolution, your wot tps % should read the same everytime though. same thing happens to me, there is no way to adjust that i kno of
this sounds dumb and you might think I am kidding... but check your floor mat.. it has been very common on this site for that to get in the way.
another thing, you could pull your TPS off and make sure that it reads from 0-100%.
