anyone in Virginia with hptuners, that i can get my car tuned with?
DRIVE HARD OR DONT DRIVE AT ALL!!!
try in the regional forums, you might have better luck.. just a though. :cheers
im in PA what part of VA you in
im in hampton but i just ordered it so nevermind. thanx anyway. but how long does it take for ppl to get it? i was reading that when they first came out, it was taking a month or longer.
it took about a week for mine
So if you have a boosted J you are better off with a standalone engine managment? I thought HP Tuners was supposed to be the shiznit what happened? This is bad because the machince shop just started my turbo buildup and I was planning to get HP Tuners pro to tune with, and whats with faking a 2 or 3 bar map? Also would I be better off starting with the GM reflash then adding HPT on top of that?
2000 Z24 5spd header & catback for now.
beyond 15psi stand alone is better
faking is discussed on shifted's website that explains it better than i can
yes if you have a 2.4 get the gm reflash and then you dont have to fake anything and you can still hp tune it
