aright my left low beam light is out. i checked the fuse thats ok. i checked the socket with my multimeter it reads 0 i tested the wires before the socket and still 0 and also tested it at the fuse box still 0. im at a loss i duno whats the deal any help would be awesome.
Does the high beam work?
Sam
Ban low-performance cars, not high-performance ones.
could be ur headlight switch
Did you have the lights on when you tested the socket? If it just stopped working then change the bulb. Most likely the problem. You should be able to see if the light is good or not just by looking at it.
high beams work brand new bulbs right outta the package and the bulbs work for the right side and also did have the light on when i tested it..... now you guys starting to see my problem
did you replace the bulb? maybe its just me but i dont understand what your saying. all your other lights work but your left low beam. just go out and get another bulb. why do all these test on wires and all. again like i said, i probably read it wrong because that seems just like an easy solutiion.
well i took the bulb from the right side cuz that works and tried it on the left and it dont work thats y im confused its not the bulb
lol alright. check the harness that plugs into the bulb and make sure the wires are good
i jus dont know where to check the wires cuz its still gittin no reading straight from the fuse box
