will a 00-02 z24 front fit on a 95-99 cavalier without having to do a headlight conversion
sure but there will be a big gap under the headlights that will need to be filled in
^^^WHAT HE SAID..get the head lights first
Sinister Ambitions
ok. i have a 95-99 z24 front and its literally crack down the middle but not all the way through the bumper. like its cracked completely in half from the bottom up to about the middle of the lisence plate. will a body shop be able to put it back together or should i just get a new one
Should be easy to repair....do it yerself...go buy a gallon of resin and some woven fiberglass cloth. align the kit, clamp it together with some vices, and put tape of the outside of the kit, brush some resin onto the inside of the kit, lay some mat, brush some more resin ontop of the mat untill its evenly soaked in resin, let set until tacky, do another layer and repeat! it will probably be about twice as strong in that area if you do enough layers and do it correctly...then take the top off the front and slap some body filler in the slight gap and then sand it down.... sorry if this post is kinda sketchy, im in a hurry!
actaully, forget teh woven cloth, its a lil easier to work with, but its not quit as strong...just use the fiberglass matt.
its gonna be hard to get glass to stick to a stock bumper
z2fst4u wrote:Should be easy to repair....do it yerself...go buy a gallon of resin and some woven fiberglass cloth. align the kit, clamp it together with some vices, and put tape of the outside of the kit, brush some resin onto the inside of the kit, lay some mat, brush some more resin ontop of the mat untill its evenly soaked in resin, let set until tacky, do another layer and repeat! it will probably be about twice as strong in that area if you do enough layers and do it correctly...then take the top off the front and slap some body filler in the slight gap and then sand it down.... sorry if this post is kinda sketchy, im in a hurry!
wrong... you'll need to have it plastic welded back together or use an epoxy. fiberglass will not repair a stock bumper.
get some type of fusor. they make different kinds for different materials
