Ok guys I just finished installing my autoloc 75lb shave door kit. Was hectic because of the size of the solenoids. So I get them installed and wired up. The Drivers door pulls a little but does not open you can actually see it pulling the wire but not enough to open it. The Pass Side you can hear it move a little but it does not pull the wire at all. I have them kinda angled in front of the door latch. Does that matter should they solenoids be straight ahead with the door latch itself? Also should i remove the rods completely or can i still have them in with the shaved kit?
hmm.. is the wire pretty tight? or loose.. mine is pretty close to the latch and its pretty tight.
<a href="http://www.whiteboy.ca"><img src="http://www.whiteboy.ca/images/whiteboysig.jpg" border="0" target="_blank">
if the wire is too tight then it wont work. i know this from personal experience.
_______________________________________________________
J-body.org Join date: Monday, January 21, 2002
AIM & Y!: COGcaviZ24
Andrew Lee wrote:if the wire is too tight then it wont work. i know this from personal experience.
me too
when i installed my kit, it took a few tries and quite a bit of adjusting to get everything to work right. this site
here was very helpful during the install. i'm not sure if it will help you though, but i'd thought i'd post it anyway
