i used to have them on my car... chk out my cardomain page, thats a long long time ago that i had them.
light output sucked ass big time! just a warning, if you get them dont plan on driving at night or in the rain unless you have a nice set of auxillary driving lights mounted up front...
also usually fitment sucks with them... either they line up perfect and look nice and the lil bit of light you get is everywhere but the road, or you get them aimed perfect but then they line up like crap....
my solution was to use OEM brackets... got them of a damaged car that cam in to the shop i work at... then they fit great and i could aim them perfect. of course light output sucked.
I heard they work great if you go the route of HID's which I didnt have at the time but now I do, but now I have different headlamp assembelies...
so yeah thats all the info i got for you hope it helps you,
if you have any questions and think i can help let me know.
laters
My car was made with wrenches, Not chopsticks.
i have the black versions of them....i did the same thing as flaked z fire... i used my oem brackets on them and they fit great now...and to tell you the truth...i cant tell the difference between them and stock light output
heres mine
signal 13 had em.... werent bright at all....
he later opted for the diamond clears that put out way more light, but basically stock style, just clear with less light absorption....
Dam-it Muffins (Event) wrote:signal 13 had em.... werent bright at all....
yeah those are the ones i have now... i love them!
Flaked Z-Fire, How do you go about changing them to the OEM brackets how do you get them apart to do this ???
just unscrew the brackets off of the aftermarket lights ( 3 screws) and then you have to do a little trimming with a dremel or somethin to get the stock brackets to sit flush ( you will see when you go to do it) then just screw the stock brackets in
The Other Matt wrote:just unscrew the brackets off of the aftermarket lights ( 3 screws) and then you have to do a little trimming with a dremel or somethin to get the stock brackets to sit flush ( you will see when you go to do it) then just screw the stock brackets in
yeppers
real easy.
hey thanks for the info i just bought these and im kinda worried about all the stuff you all was talking about lol thanks for the tips
procarpart usually has them on ebay, or you could just check their website. I also believe Aplusperformance has them
02 Subaru Impreza WRX Wagon
aplusperformance.com has them too jason could hook ya up
