Hi Guys
I have a major problem with my headlights ok here is my problem well my driverside headlight is dimmer then my passenger side headlight and when I put my brights on it just doesnt seem bright enought for brights and I need to know how I can resove this problem with my headlights.
Go Check Out My Z26 Message Board @
http://v6z26.proboards12.com/index.cgi and tell me what you think Thanks
My idea would be to replace them with silverstars or something similar. That should solve the briteness problem. As to one being dimmer than the other its my belief that whoever owned it before you had one go out and replaced ONLY that light, therefore leaving the old light untouched. From what I understand over time all lights dim just from normal use.
well see me and my dad used my passenger side light on the driverside and it still seem dim for some odd reason
There is a possibility that they are not aimed the same. Maybe try to realign your driverside lite. See it on the road all the time.
There ya go...now you'll have something to do.
