For those who don't know, I've done a 99 conversion on my 04. When I first had it done the headlights were really messed up. After being in the shop I ended up getting new head light housing which illiminated the divers side light going in and out. Well now my problem still remains that I don't have low beams, they are the same as my daytime running lights. I have to drive around with my high beams lit. They are not as bright as my highs should be, and infact both the high and low beams are lit to give a brighter effect then the low beam problem Im dealing with. Josh and I have been thinking its a wiring or wiring harness problem, someone else said possible bulb switch. Does anyone have a clue or has done a conversion and had this happen. Im really gettin tired of this, and would love to have working headlights!!!!!!!!!!!!!!!!! Thanks!
No one has any suggestions?
Im guessing its a mixed up wire....... but thats just me.
put in new bulbs, same problem? then its the wiring.
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
check the fuses, that was my problem when i did the cavfire thinger. and it sounds like the exact same problem i had.
I'll check them both. I just didn't know if anyone had the same problem. Didn't want to rip something apart for nothing.
you are going from one bulb to two bulb, how is your wiring? like how is it set up? youw ill prob need some relays..
2004 Nissan Maxima SE w/ Elite Pkg
2005 Infiniti G35 Coupe w/ Sport Pkg
The harness was replaced with the wiring. My uncle redid alot of the connection because I didn't have correct turn signals so now I have custom signals.
