Hi i just bought a 03 cavalier LS red and i was wondering if anyone has instructions on how to open up my headlight and get rid of the orange on the sides i believe it is called "cooking" i am kinda scared to do it and dont want to mess it up but dont wanna pay 200 for clear lights. if anyone can help it would be great information thanx
i know your new so i'll help you out here but in the future please learn the function of the search button. theres a ton of info out there
Clearing 03 Headlights
you will need:
2 flathead screwdrivers
7/32nd socket and rachet
oven preheated to 200 degrees farenheight
Sealant...Black preferably
rubber gloves
ok, first put the light in the oven, bake for 12 min at 200 degrees
remove, and pry the clear lens from the housing, its tough, but the black glue will separate, if its not working, try baking a little longer, the warmer the adhesive is, the easier it is to get through it
separate the black shroud from the clear lens, by prying the glue off, there is 4 tabs on each
unclip the orange reflector
remove the 2 bolts from the turn signal lens
install bolts back in turn signal housing,
clean all old sealant off of light assembly
paint shroud what color you want...or leave it black
clean all parts prior to reassembly
put it all back together, making sure to use sealant where there was before, coat the outside edges to ensure they dont leak.
reinstall on the car, and wash to make sure you dont have a leak
some pics of the prorgress on my cardomain
page 5
ok thanks for opening the link and posting the same thing i just did
actually i was copying from a different site, and thre was no reply when i opened it. quit being such a bitch
i wish i could be as cool as you
^^^^^^^^^^^^^^^^LOL
i did this twice already and those instructions will work perfrect.
workin on my 2nd set with custom Halo's and projectors
very easy...just remember...BAKE!!
not broil
does anyone know if this works on other headlights such as GTP headlights
it should, its the same concept. (if your talking about just opening the lights up)
[quote=Ozzie(aka Jäger-Boy)]workin on my 2nd set with custom Halo's and projectors
not broil
did you make your own halo's, or did you buy them pre-made??
if bought, where did you get em??
Fred Ohlson "The people that devised this cruel attempt
at acceptance and fame burn in there honda civics"
i'm makin mine custom..
IZN TRBL sells them @ his store tho
just outta curiosity--this clearing works the same on the cobalts or differently?
i assume the same, a buddy was askin me to do his..
it'll be the same on any headlight that uses sealant like that., (100
cavy:bagged easystreet front, bags to be in in back soon, tubd, 18s.
celica gt-s:6speed, AEM Cold air, hi flow cat, muffler deletion, NGK plugs, Carbon fiber headliner, B&M shift kit, sportline 2.2" drop, factory rear disk brakes
1/4: 14.5sec. top speed: 145mph
