okay i order the hood for my 04 cavalier .I have some ?`s on the trunk.I see they have 2 different carbon fiber trunk lids 95-02 and 03-05 cavaliers.Is the only thing different on the 03-05 the holes for the red piece?And witch one is better VIS or JSP?
thanks james
i cant tell you. did you search? there is probably an old post about this or with peoples opinions in it.
FOR SALE: (5) '95-'99 Z24 Rims
assuming thats the only difference but any of them will fit on a 95-05 cav. personally i would never order a cf lid. i have never seen one fit right. they always have a corner that sticks up and never sits flush
[quote=ßãggéÐÇåv98 (Ûñqùðtäß£è Øñé)]assuming thats the only difference but any of them will fit on a 95-05 cav. personally i would never order a cf lid. i have never seen one fit right. they always have a corner that sticks up and never sits flush
It will fit 95-05 Nut from what i gather, the tail lights wont match up right.
...oh no. dont tell me that, i was planning on buying one. Hopefully, my body shop can make on line up properly.
...don't hate!.. respect people that have talent, even if it is in something you don't like or understand.
i dont understand what you mean by tails not matching up right? you mean lining up from the outside and inner tails? the tails will fit any any 3rd gen cav.
i know that the jsp and vis have fitment problems w/ their lids and they dont sit correctly when its closed, this is why i have yet to order one. i know classglass makes a cf lid but its fully shaved
I think what he's talking about is the corners toward the rear glass. Most Carbon Trunks don't space correctly, which can easily be fixed when they're being attached to the rear trunk bracket.
You need to take out spacers that are on those brackets otherwise the trunk will sit too high, or you can add washers if the trunk sits too low. Either way, go with VIS they have Grade-A carbon fiber and shipping times aren't bad assuming they have it in stock.
I could probably get you a rockin' deal, send me an email!
-Jalal
www.andysautosport.com
800-419-1152 - VOICE
408-263-9526 - FAX
JalalAAS - AIM
jalalm@andysautosport.com - EMAIL
yeah classglass told me that there cf trunks are pin on`s.im starting to think twice about the trunk now. thanks for the input
thanks james
biggest prob with my trunk is that the top corners (by the rear window) curve down, but i'm gonna put little rubber bumpers under them and that should push them up.....that and for some reason 1 inner tail lines up right, but the other inner tail is a little off from the outer.
-john
almost forgot-mine's a vis trunk, and so's my hood. they both look great.
-john
