Here is the problem. I drove to my friends house and did use the brights on my car. Worked fine. When it was time to leave I started the car and the brights were still on and then the headlights died. When I turned the brights off the headlights worked fine, just no brights. When I turn on the brights the lights go dead. But the turn signal lights work, tail lights work, everything except the headlight bulbs. WTF?
http://www.cardomain.com/ride/676422/1
/\/\like he said, and relay's too. If a last resort buy some new bulb's.
Did you try checking the bulbs to see they just burned out ?
he has a 03-05 it's only one bulb.
i had the same probelm all i did was change out the relay.
__________________--------------------------____________________
Team: NONE RIGHT NOW
Sponsored By: Pro Trucks
Work Being Done By: creative customs
Stuff for Sell:
^^^^sorry not on mine but on my friends 04 cav
Stuff for Sell:
Yes, its one bulb. BUT with two filiments inside so if one of the filiments goes then so
does the light for the high or low which ever is burned out.
Checking the lights is FREE. Pull them out and look at BOTH filiments to make sure one didn't burn out. If they are both fine then start looking for things that will cost you money to try.
Jackalope wrote:Yes, its one bulb. BUT with two filiments inside so if one of the filiments goes then so
was about to say the same thing
oh ya FYI the taillights are like that too you can have turnsignals but no running and vice versa.
right but some newbies dont know 03+ only have the one bulb tho
Stuff for Sell:
i had an issue were i ordered some cheap bulbs off ebay and they drew more current than the stock wiring could handle. it fried my switch and the only thing that worked was the drl's. no low beams or highs. i would make sure that the bulbs are not stressing the switch too much or the other wiring.
jayme meulemans: how many watts where your bulbs?
get Izn Trbl to make u projectors
