What is the trick to get the head lights out far enough to actually change the bulb???
Im guessing that there are more than the 2 bolts or screws at the top of the head light. which is underneeth the radiator cover... I got a HANES Car Guide Book. and i'v searched all over...But it is all no help...its on an 02 Eco . Thanx for all the help.
nope its just the 2 bolts up top. once you get them out, tilt the light down towards you. there is a tab on the back of the lights that slip in and hold them in place. if you tilt it down towards you, it should come right out
You'll have to get a flat head and pry the tab on the corner light to seperate it from the headlight, then just unbolt the 2 bolts on top, and pull it out, you might have to pull up a lil but it will just pull right out.. the corner is what holds it in making it seem impossible.. Look in the manual for changing turnsignal bulb on a 00-02.. For prying the corner light.. there is a hole in the radiator support if u look in it u'll see something like clipped on the headlight mount, you have to pry that towards the corner light and once u unclip it the corner light will just easily pull out(maybe fall out so make sure u have a hold on it.) I wish i could provide you will pics but i don't have my 00 anymore or my headlight swap done yet..
take off the 2 bolts on the top, then look between the 2 peices, you will see a clip, thats whats holding the 2 together, once you undo the clip it comes right off
I had a problem trying to figure it out as well on my 02 cavy ( yellow too :p )
Thanx !!! for all the help...
