does anyone know or have a car with a single wiper assembly like the higher end Mercedes? OR does anyone know how to fabricate this?
Why? They look retarded. I see you just joined a few weeks ago, you should do some more reading and searching. Welcome to the ORG.
2012 HD VRSCF
2010 Ford Explorer
2006 Ford Ranger
2004 Chevy Cavalier
Fire Fighter wrote:Why? They look retarded. I see you just joined a few weeks ago, you should do some more reading and searching. Welcome to the ORG.
IE what you like is different then the org so you should read whats considered cool around here becasue opoins other then the majority arent excepted.
if you want to do this it probably wouldnt be harder then finding a car with a singel wiper setup and fabraciating a bracet and switch. stich with gm since all the fittings should be the same. sorry im not much more help but I hate to se responses that shun out of the box thinking. welcome to the org
boobs now with Riboflabin"
It can be done very easily. You just take both wiper arms off &
then put the longer one on in the centered position. I seen this
done on Gary Oxley's car a LONG LONG time ago. I personally
don't care for the "one wiper look", but to each his own. Good luck,
hope this helps...
"Your Premier Source For Automotive Neon & Accessories!"
thanks for your help and advice.
I would recomend that you don't do it being it's not legal. At least around my neck of the woods. Cops love pulling over car owners that have that one windsheild wiper set up. It also won't pass inspection in my neck of the woods either.
and if you were wondering where I am, pennsylvania.
you want it WHEN??
Here's a pic for you to see how it might look...*not my car...just a local cav* click to enlarge
Good luck if you decide to do it, and post pictures!
JBOK.org loves you
Well, way back in the day, I did it on my green car for like a week. I quickly changed back to the regular setup when I realized two things: 1) It looked completely stupid. 2) It didn't clean the windshield as well as I liked.
I saw Gary Oxley's car with the one wiper setup, too, and I always wondered why he kept it like that.
It different, if that's what you want to do, just do it how Kevin Richter said cause that's exactly how I did it.
-Crystal
I think hes talking about doing it the right way where the wiper still stays all the way down
The only way i could think to do it would be use a motor off a car that has it and adapt it to yours.
Don't do it! You don't have a civic, remember?
ever man for his own. do it and do it right, then no one can complain. Its your ride
Welcome to the ORG
http://www.cardomain.com/ride/2187947
i like the idea it's somethign diffrent i might end up trying it don't worrie about what ppl say on the org no matter what thier opinion is it's ur ride do it up n if it looks sweet keep it just watch for cops
Some VW Sciroccos came with a single 180º swing wiper.
Looks ghey to me. Unless you do it correctly where th wiper sits all the way down but that would require a new arm and possibly different motor and stops.
like said before, if your car is made with 2 wipers, you can't pass inspection with only one wiper, you need both of them
You'll never touch God's hand
I've seen the ways of God
I'll take the devil any day
Hail Satan
i love how only 2 people seemed to read his actual post. either than or none of you except 2 people know what the mercedes wipers look like. ive been sayin' this for years. if it can be done correctly like flip said where it looks like the mercedes wiper were it lays all the way down in the off position then it will look good
Right.
Basically... there are two ways to do this and I've only ever seen one done on a j-body.
There's the ghetto-ricer method, where you remove the driver's side wiper and jimmy the passenger one to rest half-way up the windshield and sweep a part of the middle of it when you turn it on. You see that all the time and it's retarded.
Then there's the proper way, which has been described here, but I've never seen actually done. This would involve making it work like the cars mentioned above where it rests below the windows and sweeps the full 180 degrees (or whatever, depending on where the pivot is) to cover as much area of the windshield as possible.
If you can make that, then by all means go to it and many of us here will be impressed.
If you're going with the first method though, don't bother. It's not cool. It's not difficult or custom. It's just stupid and anyone who knows anything knows it's stupid.
